Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Surface Pro 2 Fails to Start Up
The Surface Pro 2 will not respond or show any sign of powering up.
If you can't get your Surface Pro 2 to turn on, try the following solution:
- Force Restart: Press and hold the power button for 30 seconds. After the 30 seconds have passed , release the power button.
If forcing a restart does not solve the issue, you should consider the following:
- If there is a response with the fans or lights on your device, continue to the display issue section located above.
- If there is no response from your lights or fans, then continue reading.
Power Cable Not Charging
Check the power connector LED light. If the light is off or flashing, you may need to replace your Surface Pro 2 power supply cable.
Battery Not Powering Device
If your Surface Pro 2 turns off when while unplugged, or even when plugged in, you might want to try the following solutions to check if your Surface Pro 2 battery is functioning properly.
- Shut down and completely charge your Surface Pro.
- Remove the battery driver and install updates.
If none of the previous solutions work, then your battery may have failed. We do not recommend replacing the the battery for your own safety.
Motherboard Short Circuit
If the previous guides did not solve the problem, then it is possible that your motherboard is damaged. To replace the Surface Pro 2 motherboard, follow this link Motherboard Replacement Guide.
Display Unresponsive
The Touchscreen won't respond or fails to display.
If your screen is unresponsive to touch, or if it freezes during operation, or if it flickers constantly, or if it is cracked or fails to turn on, then carefully follow the steps below.
Unresponsive Touchscreen
If your Surface Pro 2 is sometimes unresponsive to touch, but otherwise functions properly, try these possible solutions:
- Clean any dirt and grease residue, which may have accumulated on the screen. This will make the sensors on your screen more responsive
- Reset touchscreen calibration by the calibrate tool.
- Install the latest updates by using the Update & security tool.
Cracked Screen
If the glass on your Surface Pro 2 touchscreen is damaged, It may affect the responsiveness of the touchscreen. To replace your broken screen follow this link Touchscreen Replacement Guide.
Screen Flickering
If your Surface Pro 2 screen flickers constantly, you might want to consider turning off the automatic brightness.
Screen Freezing
If your screen is randomly freezing, then you might want to try a full restart. If this does not solve the issue, you might want to consider a full factory reset, but remember to backup all of your important files first before proceeding.
Audio and Sound Distorted or Silent.
No sound is coming out from the Surface Pro 2 speakers or audio accessory, or the sound is distorted.
Speakers Distorted or Silent.
If the speakers are not working properly, try the following possible solutions:
- Remove obstructions from speaker surface
- Adjust the volume
- Install and update drivers
- Run troubleshooters
Audio Accessory Distorted or Silent.
If no sound is coming from your audio accessory, make sure that the accessory is working and connected properly.
If this does not solve the issue, the your Surface Pro 2 might have a broken audio port. In order to replace it, follow our guide Microsoft Surface Pro 2 Audio Ports Replacement|Audio Port Replacement Guide].
Camera Will Not Record
The Camera will not record or has physical damage
If your camera is not functioning even though it has not been physically damaged, you might want to download and update your camera drivers.
If this does not solve the issue, or your camera has been physically damaged, then follow this link Camera Replacement Guide.
Author
with
Mathew B
323 Reputation
2 Guides authored
USF Tampa, Team 6-2, Remmell Fall 2016 Member of USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 Members
48 Guides authored
2 Comments
I have a surface pro 2 that was working fine and someone tried to update it with a win 10 usb and ever since then the screen has been black. When I plug it into the keyboard the keyboard lights come on I can hear it turn on and off. I've tried a hard reset to no avail. The screen is just black always. I downloaded the windows 8.1 usb to try and install it back to factory settings but it wont respond to it…well actually I can here it make the sound when you plug in the usb and when you take it out. But nothing on the screen. What could have happened?? And can it be fixed??? Thanks
dusty4261 - Reply Share
Comment to Screen Flickering.
My Surface Pro 2 starts screen flickering after working more than one hour.
It is not seriously hot on the surface (ha ha "on the exterior").
After turned off it will cool down and be ready after approx. 30 minutes.
Another problem is that the single USB port died a couple of years ago.
Best regards akselkloster
Aksel Kloster - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 62
All Time: 10,726
