Microsoft Surface Pro 2 Motherboard Replacement
    1. Microsoft Surface Pro 2 Motherboard Replacement, LCD Display: step 1, image 1 of 2 Microsoft Surface Pro 2 Motherboard Replacement, LCD Display: step 1, image 2 of 2
      • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
      Ask FixBot
    2. Microsoft Surface Pro 2 Motherboard Replacement: step 2, image 1 of 1
      • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
      • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
      • The glue is under the darker border of the device display.
      Ask FixBot
    3. Microsoft Surface Pro 2 Motherboard Replacement: step 3, image 1 of 1
      • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
      • If the tool does not easily slide under the screen, return to heating before proceeding.
      • Slowly work the tool around the entire edge of the screen.
      Ask FixBot
    4. Microsoft Surface Pro 2 Motherboard Replacement: step 4, image 1 of 3 Microsoft Surface Pro 2 Motherboard Replacement: step 4, image 2 of 3 Microsoft Surface Pro 2 Motherboard Replacement: step 4, image 3 of 3
      • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
      • Please note the third small connector in red.
      • Allow the glue to cool before letting it come into contact with any other surface.
      Ask FixBot
    1. Microsoft Surface Pro 2 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Microsoft Surface Pro 2 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Microsoft Surface Pro 2 Motherboard Replacement, Motherboard: step 5, image 3 of 3
      • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
      • Remove the 22 screws on the bezel.
      • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
      • The three different torx screws used are T3, T4, and T5.
      Ask FixBot
    2. Microsoft Surface Pro 2 Motherboard Replacement: step 6, image 1 of 3 Microsoft Surface Pro 2 Motherboard Replacement: step 6, image 2 of 3 Microsoft Surface Pro 2 Motherboard Replacement: step 6, image 3 of 3
      • Once the brackets are removed, set them aside.
      • The motherboard itself also has screws.
      • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
      • View the attached photo of a screw diagram to help keep track of your screws.
      Ask FixBot
    3. Microsoft Surface Pro 2 Motherboard Replacement: step 7, image 1 of 3 Microsoft Surface Pro 2 Motherboard Replacement: step 7, image 2 of 3 Microsoft Surface Pro 2 Motherboard Replacement: step 7, image 3 of 3
      • You have now completely removed the motherboard, and it should look like the pictures shown.
      • Be sure to be cautious with all the connections with the cables on the motherboard.
      Ask FixBot
2 other people completed this guide.
Christopher Doyle
131 Reputation
1 Guide authored
USF Tampa, Team 6-2, Remmell Fall 2016 Member of USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 124
All Time: 7,818
