Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device does not power on
The digital clock and advanced functions of the watch appear to be not operating.
Lithium battery is low
The battery can be charged via Micro-USB cable to computer or power adapter.
  • A red light will indicate the watch is receiving power.
  • A green light will indicate the watch is fully charged.
  • Quick-press both buttons on the left side of the watch to power it on.
Device does not charge or stay on
The red light indicating the watch is receiving power is absent or the watch powers off soon after unplugging charging cable.
Micro-USB charging cable is damaged or faulty
Try using a different Micro-USB charging cable and/or power source.
Micro-USB charging port on device is obstructed, damaged or faulty
Visually inspect the Micro-USB charging port on watch to spot any obstructing debris, damage, and/or wear. If the five pins appear to be damaged the port will need to be replaced using this guide.
Built-in lithium polymer rechargeable battery is expired, damaged, or faulty
If the lithium polymer battery has significantly less than 5 days of use time, its it likely that the battery will need to replaced with this guide.
Analog watch is not keeping time
The time piece feature of the watch appears to be not operating.
Time piece battery is expired
Replace the small watch battery that runs the analog watch using this guide. Verify that no corrosion has built up on the battery.
Cannot communicate with other person on the line
The user is unable to hear or speak to the person over the voice connection.
Watch is incorrectly paired with phone
Follow and verify the correct parring protocol.
Background noise is too loud to permit effective communication
Make sure to operate in a quiet enough environment to hear and speak effectively.
Poor cellular connection
Consider if both parties have a good cellular reception which could be degraded in remote and obstructed areas like tunnels, basements, mountains, valleys, and forest.
Speaker and/or Microphone is faulty or damaged
The speaker and/or microphone may need to be replaced.
Unable to receive phone notifications
The user receives regular notifications on their phone, but not the smart watch
Phone and watch may not be compatible
The phone and watch may have issues with compatibility due to operating system connectivity issues. First, refer to the compatibility section for the device that comes with the smart watch. If both phone and watch are compatible, try updating both the smart watch and the phone.
Bluetooth may not function on one of the devices
Check to make sure your phone is on. Next, go to your settings and make sure your phone has Bluetooth enabled. If the watch does not automatically connect, the Bluetooth sensor on your watch may be malfunctioning.
Bluetooth may be turned off
Incorrect program downloaded to phone
This smartwatch requires a specific program in order to connect to your phone and receive notifications. Make sure that you have this program updated and that it is connected to your smart watch.
Low Batteries
Most smart devices shut down auxiliary operations, such as screen brightness and Bluetooth connections, when low on batteries. Try checking to see if both devices are charged. If one is low on batteries, charge the device for 20 minutes to rule this out as a cause of an issue.
Watch does not pair with phone
The user has a smart phone, and the smart watch is not pairing to the phone properly, due to software connectivity or hardware issues.
Low Batteries
Device loses connection with phone
If the user takes the devices out of Bluetooth signal range, they may experiences a dropped connection and loss of notifications sent between the smart watch and smart phone.
Devices are out of range from each other
Check to make sure the phone and smart watch are not registering with each other. take both devices and move them close to each other (less than 5 feet) to make sure they are in sufficient signal range for each other.
Low Batteries
Device fails to reconnect after returning into range
After moving with in range of Bluetooth, both devices do not reconnect.
Low Batteries
Digital time on watch not in sync with cell phones time
The digital time on the watch does not match the time on the paired phone.
Low Batteries
Bluetooth connection lost
Glitch
There could be an issue with the physical hardware or software of the issue. Try restarting the watch and/or phone.
Martian Victory
Author
with
Kelsea Weber
21,643 Reputation
32 Guides authored
iFixit, Team S1-G1, Weber Summer 2018 Member of iFixit, Team S1-G1, Weber Summer 2018
FIX-WEBER-SU18S1G1
5 Members
396 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 2,013
