Martian Victory Analog Watch Battery Replacement
Views: 10K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
110
All Time:
10,219
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will illustrate how to replace the analog battery in the Martian Victory watch.
It is very important to tell your users to use the correct tool for the job. Metal spudgers and screwdrivers can damage delicate internal components and puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
Parts
Tools
    1. Martian Victory Analog  Watch Battery Replacement, Back Plate: step 1, image 1 of 2 Martian Victory Analog  Watch Battery Replacement, Back Plate: step 1, image 2 of 2
      • Unscrew the four 3.4 mm flat head screws
      Ask FixBot
    2. Martian Victory Analog  Watch Battery Replacement: step 2, image 1 of 1
      • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
      Ask FixBot
    1. Martian Victory Analog  Watch Battery Replacement, Lithium Battery: step 3, image 1 of 1
      • If not replacing lithium battery, skip down two steps.
      • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
      Ask FixBot
    2. Martian Victory Analog  Watch Battery Replacement: step 4, image 1 of 1
      • Desolder the battery connections from the motherboard. Learn how to solder components here!
      Ask FixBot
    1. Martian Victory Analog  Watch Battery Replacement, Motherboard: step 5, image 1 of 1
      • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
      Ask FixBot
    2. Martian Victory Analog  Watch Battery Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
      Ask FixBot
    3. Martian Victory Analog  Watch Battery Replacement: step 7, image 1 of 1
      • Use PH00 screwdriver to remove 5.2mm Phillips head screw
      Ask FixBot
    4. Martian Victory Analog  Watch Battery Replacement: step 8, image 1 of 3 Martian Victory Analog  Watch Battery Replacement: step 8, image 2 of 3 Martian Victory Analog  Watch Battery Replacement: step 8, image 3 of 3
      • Use ESD safe tweezers to remove the gold ribbon cable.
      • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
      Ask FixBot
    5. Martian Victory Analog  Watch Battery Replacement: step 9, image 1 of 2 Martian Victory Analog  Watch Battery Replacement: step 9, image 2 of 2
      • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
      • You can now access the parts and pieces on the bottom of, and below the motherboard.
      Ask FixBot
    1. Martian Victory Analog  Watch Battery Replacement, Analog Watch Battery: step 10, image 1 of 1
      • Use a spudger to lift the battery from the back case.
      Ask FixBot
2 other people completed this guide.
David Miller
246 Reputation
2 Guides authored
IUPUI, Team 3-3, Baechle Fall 2016 Member of IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Members
96 Guides authored
3 Guide Comments
I am researching for methods to change batteries on a watch. Would like to thank you for this piece. It is really good. However, you have used some tools in your tutorial. but since they pins and scissors are in everyone's home, making your way easy
I shall be writing a post in the same topic. and would love to feature your guide on it..
Thanks
Ronald Mckim
Owner: http://www.mywatchvilla.com/
Ronald Mckim - Reply Share
@ronaldmckim, you may embed our guide using the instructions here: https://ifixit.org/blog/8474/embed-guide.... For our content licensing policies, see: Content Licensing.
Cynthia Replogle - Reply Share
Hi.. Thank you for the detailed steps, it really helped a lot in replacing the analog battery ourselves
However, now we are not able to place the mother board back in its place, hence wanted to check if there is any tips or steps or screenshots how we can place it back?
Ashwin kochar - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 110
All Time: 10,219
