Up to 20% off select tools
Micro-USB Port Replacement
Views: 19K
View statistics:
Past 24 Hours:
4
Past 7 Days:
48
Past 30 Days:
208
All Time:
19,054
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Very difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
    1. Micro-USB Port Replacement, Back Plate: step 1, image 1 of 2 Micro-USB Port Replacement, Back Plate: step 1, image 2 of 2
      • Unscrew the four 3.4 mm flat head screws
      Ask FixBot
    2. Micro-USB Port Replacement: step 2, image 1 of 1
      • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
      Ask FixBot
    1. Micro-USB Port Replacement, Lithium Battery: step 3, image 1 of 1
      • If not replacing lithium battery, skip down two steps.
      • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
      Ask FixBot
    2. Micro-USB Port Replacement: step 4, image 1 of 1
      • Desolder the battery connections from the motherboard. Learn how to solder components here!
      Ask FixBot
    1. Micro-USB Port Replacement, Motherboard: step 5, image 1 of 1
      • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
      Ask FixBot
    2. Micro-USB Port Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
      Ask FixBot
    3. Micro-USB Port Replacement: step 7, image 1 of 1
      • Use PH00 screwdriver to remove 5.2mm Phillips head screw
      Ask FixBot
    4. Micro-USB Port Replacement: step 8, image 1 of 3 Micro-USB Port Replacement: step 8, image 2 of 3 Micro-USB Port Replacement: step 8, image 3 of 3
      • Use ESD safe tweezers to remove the gold ribbon cable.
      • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
      Ask FixBot
    5. Micro-USB Port Replacement: step 9, image 1 of 2 Micro-USB Port Replacement: step 9, image 2 of 2
      • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
      • You can now access the parts and pieces on the bottom of, and below the motherboard.
      Ask FixBot
    1. Micro-USB Port Replacement, Micro-USB Port: step 10, image 1 of 1
      • Locate the four main soldering points marked in red.
      • Be aware of the five additional soldered pins marked by the blue arrow.
      Ask FixBot
    2. Micro-USB Port Replacement: step 11, image 1 of 3 Micro-USB Port Replacement: step 11, image 2 of 3 Micro-USB Port Replacement: step 11, image 3 of 3
      • Begin to desolder the points pointed out in the last step.
      • Use the soldering wick to help remove the solder.
      Ask FixBot
3 other people completed this guide.
Author
with
Michael Miller
281 Reputation
2 Guides authored
IUPUI, Team 3-3, Baechle Fall 2016 Member of IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Members
96 Guides authored
1 Guide Comment
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
amupis232389 - Reply Share
Past 24 Hours: 4
Past 7 Days: 48
Past 30 Days: 208
All Time: 19,054
