Martian Victory Lithium Battery Replacement
  1. Martian Victory Lithium Battery Replacement, Back Plate: step 1, image 1 of 2 Martian Victory Lithium Battery Replacement, Back Plate: step 1, image 2 of 2
    • Unscrew the four 3.4 mm flat head screws
    Ask FixBot
  2. Martian Victory Lithium Battery Replacement: step 2, image 1 of 1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
    Ask FixBot
  3. Martian Victory Lithium Battery Replacement, Lithium Battery: step 3, image 1 of 1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
    Ask FixBot
  4. Martian Victory Lithium Battery Replacement: step 4, image 1 of 1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
    Ask FixBot
David Miller
246 Reputation
2 Guides authored
IUPUI, Team 3-3, Baechle Fall 2016 Member of IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Members
8 Guides authored
1 Guide Comment
I’m wondering… where did you buy the replacement battery?
Randy Trask - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,154
