Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
GPS Doesn’t Connect
The GPS displays an error message and is unable to connect
GPS Is Not Connected
If the error message says “Please connect a GPS device,” the GPS is likely not connected to the stereo. Gain access to the back of the stereo (may require disassembling the car dash) and check the cable that connects the GPS to the stereo to verify it is fully seated. Disconnect and inspect the connector leads to verify they are clean and free of debris.
GPS Antenna Is Not Connected
If the error message says “Obtaining satellite lock,” the GPS is likely not connected to the satellite antenna. Gain access to the GPS device and check the cable that connects the GPS antenna to the GPS device to verify it is fully seated. Disconnect the antenna and inspect the connector leads to verify they are clean and free of debris.
GPS Connector Is Faulty
Remove the stereo and follow this guide to open the device.
Use a multimeter to test the connector to verify that all pins are making contact with the circuit board. If there is one or more pins that are not making electrical connection, follow the connector repair/replacement guide <connector replacement guide> to replace the connector.
Display Doesn’t Turn On
The car is on, and sound is coming from the stereo, but the display appears blank
The Screen Connection Is Faulty
The wires that provide signals to the touch screen are flexible and thin, and thus can wear down easily. You will need to observe them to confirm that they are still in operation.
1. Disassemble the stereo using the replacement guide and inspect the display cable connection to verify it is fully connected.
2. Disconnect and inspect the cable leads for dirt/debris, clean, and reconnect.
The LCD Contrast Level Is Set Too Low
Check if the display is on and very dim, cover the stereo and your head with a dark towel to see if you can see the text and images. If so, enter the settings menu and increase the contrast.
Pressing the reset button will also reset the contrast level to default.
CAUTION: this will restore all settings to their default values.
The LCD Is Dead
If the cable connection is good and resetting the device did not restore the contrast, they display may be bad. Follow the LCD replacement guide to replace the LCD. <LCD replacement guide link>
The Screen Is Physically Damaged
If the screen is damaged, it can be replaced by following our replacement guide.
Bluetooth Doesn’t Connect
I cannot connect my phone/mp3 player to my stereo with Bluetooth
Bluetooth Is Disabled
Bluetooth will need to be re-enabled.
1. Touch the [MENU] button from any screen, the top menu screen should appear.
2. Tap [SETUP], wait for the setup screen to appear, then choose [BLUETOOTH].
Paired Device Is Not Available
Bluetooth is a low-range, low-energy form of wireless communication within a limited range. At times, your connection may be severed with your phone unable to reconnect. When this occurs, it is best to re-pair your phone to your Kenwood stereo.
3. Touch [SEARCH] on the right-hand side of the screen and give the stereo some time to search for active devices.
4. The list-device screen will appear once the search has completed.
5. Select your phone from the list and enter the 4 digit security code when prompted. By default, this code is “0000”, but it can be modified to be more secure.
CDs Will Not Play
I cannot play or insert a CD in the CD drive
The CD Will Not Insert
Check that there is not a CD already loaded. Press eject to see if a CD is already loaded. If so, remove it and insert the new CD.
If there is no CD inserted, listen closely to the stereo, if you hear a motor buzzing, then it is trying to load a CD but something is preventing it. Disassemble the stereo and check the CD motor to verify it is properly aligned and is placing enough tension on the CD to pull it in to the stereo.
If the stereo does not make a buzzing motor sound when inserting the CD, the CD sensor may be dirty or bad. Disassemble the CD player and check the sensor for dirt and debris and if it is not dirty or blocked, follow the replacement guide to replace the sensor.
The Stereo Is Not in CD Mode
Scroll left or right until you see the “Disc” icon with an image of a CD and touch it to enter CD player mode.
The disc that is in the drive is not an audio disc
The stereo supports multiple optical media types including DVD, VCD, and Data discs as well as audio discs. Eject the disc and verify that it is an audio CD.
The CD Drive motor is bad
Disassemble the CD player and check the wire connections on the CD drive motor. If they are good, check if the motor is receiving power when CD player mode is enabled. If it is, then replace the motor, if it is not, check the motor driver for a broken connection, if no bad connections are found, replace the motor driver.
The CD Drive read laser Is Broken
If the motor is spinning but the CD is not playing, the read laser may be defective. Follow the replacement guide to replace the laser or the CD drive.
Satellite Radio Is Not Connected
I cannot connect to satellite radio on my stereo
The Satellite Device Is Not Connected
If the error message says “Please connect a satellite device,” the satellite receiver is not properly connected. Check the connector that links the stereo to the satellite receiver on each of those devices for device for dust or debris.
Satellite Antenna Connection Is Faulty
If the error message says “No signal available,” there is an issue with the satellite antenna. Satellite antenna requires “line-of-sight” connection to an orbiting satellite and will not function in areas with tall buildings or inside large structures such as parking garages
1. Check the location of the vehicle and test if moving to an open area with clear visibility of the sky allows the signal to return.
2. Check the satellite antenna cable connection to verify it is fully connected.
3. If you have a clear view of the sky and the antenna connection is good, the problem may be with the satellite antenna connector on the main board. Follow this guide to replace it.
Can’t Receive Local Radio Stations
I cannot tune to any local radio stations
Vehicle Antenna Connection Is Faulty
Check the antenna connection on the back of the stereo to verify it is connected. Disconnect and reconnect after inspecting for dirt and debris.
Bad AM/FM Reception
There may be an obstruction blocking the radio signals from reaching the car. FM radio signals can transmit through some structures and earth, and have a larger range than AM signals which require line of sight.
1. For AM radio, acquire line of sight to a radio tower and try again. If the connection still is not established, you may have to replace your radio or radio-coax input on the back of the stereo. Follow this guide to replace the antenna connector.
2. For FM radio, drive closer to a radio tower to attempt to boost the signal. Line of sight is not required as long as the obstructions are not large pieces of land mass
3. For either form of radio signal, exit any tunnel, building, or large structure that you may be in and try to connect again
Michael Dandrea
69 Reputation
0 Guides authored
4 Comments
Contain the main computer board that holds a navigation chip goes to heat up and goes bad in HD radio double din
Jackie Jones - Reply Share
My radio keeps resetting everytime I turn my car on?
willard paige - Reply Share
So I bought this radio used and he said it worked wen he disconnected but now red light comes on and u hear power but after about 5 minute lite geos off to
Leroy - Reply Share
I bought this kenwood used and wen I hook it up red light comes on for 5 minutes and then it geos off but I can't get the radio it's self on
Leroy - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 60
All Time: 10,377
