Kenwood DNX571HD GPS Antenna Connection Replacement
  1. Kenwood DNX571HD GPS Antenna Connection Replacement, CD/DVD Drive: step 1, image 1 of 2 Kenwood DNX571HD GPS Antenna Connection Replacement, CD/DVD Drive: step 1, image 2 of 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
    Ask FixBot
  2. Kenwood DNX571HD GPS Antenna Connection Replacement: step 2, image 1 of 3 Kenwood DNX571HD GPS Antenna Connection Replacement: step 2, image 2 of 3 Kenwood DNX571HD GPS Antenna Connection Replacement: step 2, image 3 of 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
    Ask FixBot
  3. Kenwood DNX571HD GPS Antenna Connection Replacement: step 3, image 1 of 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
    Ask FixBot
  4. Kenwood DNX571HD GPS Antenna Connection Replacement: step 4, image 1 of 3 Kenwood DNX571HD GPS Antenna Connection Replacement: step 4, image 2 of 3 Kenwood DNX571HD GPS Antenna Connection Replacement: step 4, image 3 of 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
    Ask FixBot
  5. Kenwood DNX571HD GPS Antenna Connection Replacement: step 5, image 1 of 1
    • Lift the CD drive carefully to expose the attached cable underneath.
    Ask FixBot
  6. Kenwood DNX571HD GPS Antenna Connection Replacement: step 6, image 1 of 2 Kenwood DNX571HD GPS Antenna Connection Replacement: step 6, image 2 of 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
    Ask FixBot
  7. Kenwood DNX571HD GPS Antenna Connection Replacement, Cooling Fan: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully unplug the fan power cord with the tweezers.
    Ask FixBot
  8. Kenwood DNX571HD GPS Antenna Connection Replacement: step 8, image 1 of 2 Kenwood DNX571HD GPS Antenna Connection Replacement: step 8, image 2 of 2
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
    Ask FixBot
  9. Kenwood DNX571HD GPS Antenna Connection Replacement: step 9, image 1 of 2 Kenwood DNX571HD GPS Antenna Connection Replacement: step 9, image 2 of 2
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
    Ask FixBot
  10. Kenwood DNX571HD GPS Antenna Connection Replacement: step 10, image 1 of 3 Kenwood DNX571HD GPS Antenna Connection Replacement: step 10, image 2 of 3 Kenwood DNX571HD GPS Antenna Connection Replacement: step 10, image 3 of 3
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
    Ask FixBot
  11. Kenwood DNX571HD GPS Antenna Connection Replacement: step 11, image 1 of 1
    • Lift the top part of the unit up from the lower chassis.
    Ask FixBot
  12. Kenwood DNX571HD GPS Antenna Connection Replacement: step 12, image 1 of 2 Kenwood DNX571HD GPS Antenna Connection Replacement: step 12, image 2 of 2
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
    Ask FixBot
  13. Kenwood DNX571HD GPS Antenna Connection Replacement, GPS Antenna Connection: step 13, image 1 of 2 Kenwood DNX571HD GPS Antenna Connection Replacement, GPS Antenna Connection: step 13, image 2 of 2
    • Using a spudger, undo the clasp to disconnect the large white ribbon cable.
    Ask FixBot
  14. Kenwood DNX571HD GPS Antenna Connection Replacement: step 14, image 1 of 1
    • Remove the 5mm screw with teeth from the casing with a Phillips #1 screwdriver.
    Ask FixBot
  15. Kenwood DNX571HD GPS Antenna Connection Replacement: step 15, image 1 of 1
    • Remove the four 5mm screws with a Phillips #1 screwdriver.
    Ask FixBot
  16. Kenwood DNX571HD GPS Antenna Connection Replacement: step 16, image 1 of 2 Kenwood DNX571HD GPS Antenna Connection Replacement: step 16, image 2 of 2
    • Remove the 5.5mm screw from the HDMI cable cover using a Phillips #2 screwdriver.
    Ask FixBot
  17. Kenwood DNX571HD GPS Antenna Connection Replacement: step 17, image 1 of 1
    • Remove the 5mm screw with a Phillips #1 screwdriver.
    Ask FixBot
  18. Kenwood DNX571HD GPS Antenna Connection Replacement: step 18, image 1 of 2 Kenwood DNX571HD GPS Antenna Connection Replacement: step 18, image 2 of 2
    • Remove the two 5.5mm screws from the back.
    • Lift the upper portion of the stereo free from the chassis.
    Ask FixBot
  19. Kenwood DNX571HD GPS Antenna Connection Replacement: step 19, image 1 of 2 Kenwood DNX571HD GPS Antenna Connection Replacement: step 19, image 2 of 2
    • Remove the two screws underneath the GPS connector.
    • Desolder the GPS connector.
    • The GPS antenna is a thru-hole-mounted device. You must apply heat to each soldered pin individually and pull them out of the holes while the solder is molten.
    • The solder material, pins, and any surrounding material will get VERY hot while melting the connections. Do not touch any metal parts during the desoldering process and give the device time to cool off once you’re finished. It may also be good to take breaks so that the electronics aren’t kept hot for extended periods of time.
    Ask FixBot
  20. Kenwood DNX571HD GPS Antenna Connection Replacement: step 20, image 1 of 1
    • To remove and reinsert the connector, on the top side of the board, use your finger to gently lift the metal plate to get enough clearance.
    Ask FixBot
Wendy Zaballos
976 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 1,299
