Kenwood DNX571HD CD/DVD Drive Replacement
  1. Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: step 1, image 1 of 2 Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: step 1, image 2 of 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD CD/DVD Drive Replacement: step 2, image 1 of 3 Kenwood DNX571HD CD/DVD Drive Replacement: step 2, image 2 of 3 Kenwood DNX571HD CD/DVD Drive Replacement: step 2, image 3 of 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD CD/DVD Drive Replacement: step 3, image 1 of 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD CD/DVD Drive Replacement: step 4, image 1 of 3 Kenwood DNX571HD CD/DVD Drive Replacement: step 4, image 2 of 3 Kenwood DNX571HD CD/DVD Drive Replacement: step 4, image 3 of 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD CD/DVD Drive Replacement: step 5, image 1 of 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD CD/DVD Drive Replacement: step 6, image 1 of 2 Kenwood DNX571HD CD/DVD Drive Replacement: step 6, image 2 of 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Wendy Zaballos
976 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 71
All Time: 1,452
