Jazz Digi-Stix Won't Turn On
The camera will not turn on.
Dead battery
If the camera does not turn on, the most likely cause is that you have a dead battery. Try replacing your batteries to see if this is the cause.
Broken power switch
If the power switch is stuck in place, or has no effect when it is turned on, then it may require replacement.
Bad circuit board
If the above steps dont fix the problem, replace the circuit board.
Camera Won't Take Pictures
The camera turns on, but it won't take pictures.
Capture button is broken
If the capture button is stuck, loose, visibly cracked, or has no effect, try replacing it.
Bad circuit board
If the above step doesn't fix the problem, replace the circuit board.
The camera won't record any sound
The camera won't record any sound.
Bad microphone
If your video clips have no sound, try replacing the microphone.
Bad circuit board
I can't see through the viewer
The image seen through the viewer is unclear.
Broken Viewer
The viewer may be cracked or scratched, which would cause a blurry image to be seen through it. Replace the viewer to fix this problem.
The Case Is Broken
The case is cracked or completely broken.
If the case has been dropped or impacted, it may be cracked. If this is the true, replace the case.
Photographs Are of Poor Quality
The pictures taken are unclear.
Dirty lens
Poor quality photos could be a result of a dirty lens. To clean the lens, apply lens cleaner to the lens and use a soft cloth to polish the lens.
Camera was moving while photo was captured
A poor quality photo could also be caused by motion of the camera while the photo was taken.
Hold still while taking pictures, excessive movement may cause objects to appear blurred.
Broken lens
If the previous steps are not the solution, your lens may be cracked or broken. To fix this, replace the lens.
My Photos Won't Upload
After plugging the camera into the computer, the photos won't transfer to the computer.
Camera lacks the appropriate drivers
Follow the link to download the appropriate drivers. These drivers allow for proper function of the device.
Webcam Connectivity
The webcam function on the camera will not work.
My Photos Were Erased
Photos seemingly disappear from the camera's memory
Upload photos before powering the camera off. Upon powering off, the camera's internal memory will erase. To make sure that no photos are lost, they must be uploaded before the camera is turned off or dies.
To return to device page:
Device Page
True Hines
1 Reputation
0 Guides authored
Clemson, Team 12-3, Benson Spring 2013 Member of Clemson, Team 12-3, Benson Spring 2013
CLEM-BENSON-S13S12G3
3 Members
84 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 1,000
