Jazz Digi-Stix JDC11 Case Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
39
All Time:
583
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
This guide will aid the user in the installation of a new case for this device. The new case will include the front case, the back case, and the battery cover flap. This guide will require the user to remove all of the internal parts of the device. This guide should be used if the case gets cracked, scratched, or otherwise damaged in some way.
Tools
    1. Jazz Digi-Stix JDC11 Case Replacement, Battery: step 1, image 1 of 2 Jazz Digi-Stix JDC11 Case Replacement, Battery: step 1, image 2 of 2
      • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
      Ask FixBot
    2. Jazz Digi-Stix JDC11 Case Replacement: step 2, image 1 of 1
      • Tilt device so that batteries slide out.
      Ask FixBot
    1. Jazz Digi-Stix JDC11 Case Replacement, Capture Button: step 3, image 1 of 3 Jazz Digi-Stix JDC11 Case Replacement, Capture Button: step 3, image 2 of 3 Jazz Digi-Stix JDC11 Case Replacement, Capture Button: step 3, image 3 of 3
      • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
      • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
      Ask FixBot
    2. Jazz Digi-Stix JDC11 Case Replacement: step 4, image 1 of 3 Jazz Digi-Stix JDC11 Case Replacement: step 4, image 2 of 3 Jazz Digi-Stix JDC11 Case Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • There are two wires (one red and one black) that could get disconnected from the motherboard when prying the case apart.
      • Gently seperate the two halves of the device.
      • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
      • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
      Ask FixBot
    3. Jazz Digi-Stix JDC11 Case Replacement: step 5, image 1 of 1
      • Carefully separate the grey side bar from the case and set it aside.
      Ask FixBot
    4. Jazz Digi-Stix JDC11 Case Replacement: step 6, image 1 of 1
      • Use the tweezers to grasp the bottom of the capture button. Pull the capture button away from the case and set it aside.
      Ask FixBot
    1. Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: step 7, image 1 of 3 Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: step 7, image 2 of 3 Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: step 7, image 3 of 3
      • To remove the microphone from the case, insert the tip of the spudger under the microphone's edge and pry it away from the case.
      Ask FixBot
    2. Jazz Digi-Stix JDC11 Case Replacement: step 8, image 1 of 3 Jazz Digi-Stix JDC11 Case Replacement: step 8, image 2 of 3 Jazz Digi-Stix JDC11 Case Replacement: step 8, image 3 of 3
      • Unscrew the three 5.6 mm Phillips #00 screws that connect the battery compartment to the case.
      • Remove the battery compartment from the case of the device.
      Ask FixBot
    1. Jazz Digi-Stix JDC11 Case Replacement, Case: step 9, image 1 of 2 Jazz Digi-Stix JDC11 Case Replacement, Case: step 9, image 2 of 2
      • Remove viewer from the top-left corner of the case by gently pulling it away.
      Ask FixBot
    2. Jazz Digi-Stix JDC11 Case Replacement: step 10, image 1 of 1
      • If the replacement case does not have a wrist strap, remove your device's wrist strap by feeding the plastic tab through the loop cord, and then pulling it all the way through.
      Ask FixBot
Katelyn Fry
1 Reputation
7 Guides authored
Clemson, Team 12-3, Benson Spring 2013 Member of Clemson, Team 12-3, Benson Spring 2013
CLEM-BENSON-S13S12G3
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 39
All Time: 583
