Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Problems users might run into with the JBL Flip.
Flip won't charge or battery dies quickly
The Flip cannot hold a charge or does not satisfy the battery life that is advertised. Battery will need to be replaced. Visit the guide to fix battery issues here.
Flip's speakers has audio problems
The speakers do not produce any sound at all or the sound is very muffled you will have to replace the speakers. For speaker replacement click here
Buttons do not work easily
If the buttons do not respond you can slightly take apart the Flip to fix button issues. More than likely the sensors are not screwed on tightly enough.
Bluetooth does not work
Your Flip may not have a newer upgraded antenna; this can be fixed by introducing a new antenna. To upgrade the quality of your antenna visit the Bluetooth antenna replacement guide here.
Getting into the Flip
Most problems that occur will require disassembling the Flip. For instructions on how to disassemble the device see the following guide Back panel disassembly.
Author
with
Brandon Velasquez
113 Reputation
0 Guides authored
46 Comments
I have the JBL flip 2 portable Bluetooth speaker and the light on it which says its on won't turn off when I touch the botton to turn it off and I'm not sure if it's actually turning off or not and when I plug it into charge the lights don't show that it is charging also it isn't connecting to my phone or any device any ideas what is wrong with it?
Caitlin Adams - Reply Share
Tengo un JBL Flip altavoz portátil Bluetooth y me conecta perfectamente a cualquier dispositivo pero al reproducir el audio esta cortado o pausado con Bluetooth y Auxiliar.
DjMarvin Productions - Reply Share
I have a charged flip 2 when I push the power button the phone light lights up but when I release the power button the speaker isn't on and won't power up. When I plugged it into the wall the phone lights up but still no power to the speaker tried using my aux wile it was plugged in and still nothing
Chris - Reply Share
I have the exact problem. Do you think we just got bacd speakers?
Soorya Townley - Reply Share
How can i turn the bluetooth off?
for example I connect the speaker to the PC with AUX connection, but still the bluetooth light keeps flashing as if it searches for a device.
Is it possible to turn the bluetooth off on the speaker so it will work only with AUX and stop looking for a bluetooth connection?
Thanks.
alex - Reply Share
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 47
All Time: 102,321
