JBL Flip Speaker Replacement
Views: 44K
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
169
All Time:
44,052
Comments: 11
2 comments on steps, 9 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Within this guide the user will learn and follow the steps to replace the internal speakers of the JBL Flip. A soldering iron will be used to unsolder some wired connections. To safely use the soldering iron please visit this desoldering guide How To Solder and Desolder Connections.
Tools
    1. JBL Flip Speaker Replacement, JBL Flip disassembly: step 1, image 1 of 3 JBL Flip Speaker Replacement, JBL Flip disassembly: step 1, image 2 of 3 JBL Flip Speaker Replacement, JBL Flip disassembly: step 1, image 3 of 3
      • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
      • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
      Ask FixBot
    2. JBL Flip Speaker Replacement: step 2, image 1 of 3 JBL Flip Speaker Replacement: step 2, image 2 of 3 JBL Flip Speaker Replacement: step 2, image 3 of 3
      • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
      Ask FixBot
    3. JBL Flip Speaker Replacement: step 3, image 1 of 3 JBL Flip Speaker Replacement: step 3, image 2 of 3 JBL Flip Speaker Replacement: step 3, image 3 of 3
      • Remove outermost white casing by gently lifting up on one side.
      • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
      • Gently lift up and remove the silver casing.
      Ask FixBot
    4. JBL Flip Speaker Replacement: step 4, image 1 of 1
      • Remove last white back plate to expose the back of the speaker cover.
      Ask FixBot
    5. JBL Flip Speaker Replacement: step 5, image 1 of 3 JBL Flip Speaker Replacement: step 5, image 2 of 3 JBL Flip Speaker Replacement: step 5, image 3 of 3
      • Pry the four tabs on each side of the speaker cover (8 tabs total).
      • Pry the two tabs on each end to remove the cover (4 tabs total).
      • Slide speaker out of metal speaker cover.
      Ask FixBot
    6. JBL Flip Speaker Replacement: step 6, image 1 of 3 JBL Flip Speaker Replacement: step 6, image 2 of 3 JBL Flip Speaker Replacement: step 6, image 3 of 3
      • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
      • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
      • Open the speaker.
      Ask FixBot
    1. JBL Flip Speaker Replacement, Speaker: step 7, image 1 of 3 JBL Flip Speaker Replacement, Speaker: step 7, image 2 of 3 JBL Flip Speaker Replacement, Speaker: step 7, image 3 of 3
      • Remove screws that hold the plastic L-pipe in place.
      Ask FixBot
    2. JBL Flip Speaker Replacement: step 8, image 1 of 2 JBL Flip Speaker Replacement: step 8, image 2 of 2
      • Remove L-pipe.
      • Remove two screws on each speaker.
      • Remove speakers.
      Ask FixBot
    3. JBL Flip Speaker Replacement: step 9, image 1 of 3 JBL Flip Speaker Replacement: step 9, image 2 of 3 JBL Flip Speaker Replacement: step 9, image 3 of 3
      • Take a soldering iron to the two solders, one for each cable.
      • Soldering iron will be very hot.
      • Once the soldering has melted, remove each wire from the speaker.
      Ask FixBot
9 other people completed this guide.
Dillon
1,622 Reputation
5 Guides authored
9 Guide Comments
I want JBL flip 2 charging commector board.
Where can i buy ??
Plz help me
feroz4u786 - Reply Share
Where do you buy the replacement speakers?
ingridxpan - Reply Share
I have a problem with the bluetooth of my speaker goes off after 10 minutes of running I have checked with several smart and it always repeats that I can do
Alvaro Rivas Rodriguez - Reply Share
Where I can get schematic diagram and plans of this equipment
I want to buy 2pcs replacement speaker for my JBL flip bluetooth speaker. Ho can I buy .and from
jonessangeeta - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 169
All Time: 44,052
