Up to 20% off select tools
JBL Flip disassembly
Views: 25K
View statistics:
Past 24 Hours:
8
Past 7 Days:
50
Past 30 Days:
242
All Time:
24,765
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The JBL Flip 1 is an excellent speaker, but we have noticed there are some issues with it. In order to fix these issues, you must first understand how to disassemble the Flip’s outer layers. This guide will teach you how to do this safely and precisely.
    1. JBL Flip disassembly, JBL Flip disassembly: step 1, image 1 of 3 JBL Flip disassembly, JBL Flip disassembly: step 1, image 2 of 3 JBL Flip disassembly, JBL Flip disassembly: step 1, image 3 of 3
      • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
      • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
      Ask FixBot
    2. JBL Flip disassembly: step 2, image 1 of 3 JBL Flip disassembly: step 2, image 2 of 3 JBL Flip disassembly: step 2, image 3 of 3
      • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
      Ask FixBot
    3. JBL Flip disassembly: step 3, image 1 of 3 JBL Flip disassembly: step 3, image 2 of 3 JBL Flip disassembly: step 3, image 3 of 3
      • Remove outermost white casing by gently lifting up on one side.
      • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
      • Gently lift up and remove the silver casing.
      Ask FixBot
    4. JBL Flip disassembly: step 4, image 1 of 1
      • Remove last white back plate to expose the back of the speaker cover.
      Ask FixBot
    5. JBL Flip disassembly: step 5, image 1 of 3 JBL Flip disassembly: step 5, image 2 of 3 JBL Flip disassembly: step 5, image 3 of 3
      • Pry the four tabs on each side of the speaker cover (8 tabs total).
      • Pry the two tabs on each end to remove the cover (4 tabs total).
      • Slide speaker out of metal speaker cover.
      Ask FixBot
    6. JBL Flip disassembly: step 6, image 1 of 3 JBL Flip disassembly: step 6, image 2 of 3 JBL Flip disassembly: step 6, image 3 of 3
      • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
      • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
      • Open the speaker.
      Ask FixBot
12 other people completed this guide.
Author
with
Dillon
1,643 Reputation
5 Guides authored
4 Guide Comments
How do i take apart jbl flip 3
Ricky Tomas - Reply Share
My jbl flip 3 Bluetooth button does not function.How do I fix the problem?
Francis
fwathika - Reply Share
The charging PCB on my Flip3 is damaged and needs to be replaced. Any chance of purchasing the charging/interface module, fully populated?
I live in South Africa, and cannot find it here!
Paul M
Paul Moulang - Reply Share
The charging PCB on my JBL Flip3 is also damaged and needs to be replaced. Any chance of purchasing the charging/interface module?
I live in Pune - Maharashtra in India and cannot find a good reliable service station for JBL speakers here!
Suresh Karve
Suresh Karve - Reply Share
Past 24 Hours: 8
Past 7 Days: 50
Past 30 Days: 242
All Time: 24,765
