Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
This troubleshooting page will help you diagnose problems with the Hover-1 Rally electric scooter.
Brakes Will Not Stop the Scooter
The scooter does not slow down or stop when pressing the brake.
Brake Pad is Worn Out
Over time, the brake pads on your Hover-1 Rally Scooter will wear down and become ineffective. Avoid riding in dust and other debris to increase the lifespan of your brake pads. If your brake pads are worn down, consider replacing them.
Brake Switch is Not Working
If the brake pad is not worn down, the brake switch might be the problem. First check that the handle is screwed on tightly. Then, examine the edges of the brake switch for any loose debris stuck inside. If the brake switch has free range of motion, it may be time to replace the brake switch.
Wheel Will Not Spin
The back wheel will not spin at full speed or will not move at all.
The Device Has Not Been Turned On
If the wheel will not turn, the scooter may not be powered on. The power button is located near the display screen on the scooter’s handlebars. To power the scooter on, press and hold the power button for 3 seconds. The display should notify you when the scooter is on.
Debris Blocking the Wheel
The wheel may lock up if there is a buildup of dust, dirt, leaves, or sticks between the spokes. The spokes are straight rods connecting the wheel’s center to the outside circle. Simply dislodge the debris from the stokes of the wheel to fix this issue.
The Screws, Axle, or Washers are Rusted
If the wheel does not move after removing debris, parts of the wheel may be worn down or rusted. Consider replacing the rear wheel.
The Bearings Are Rusted
If the wheel is in good condition but continues to move at slower speeds, examine the bearings for rust or damage. The bearings are located behind the wheel. If they are damaged, replace the wheel’s bearings.
Scooter Will Not Charge
The scooter fails to charge when plugged in.
Charging Port is Damaged
If you cannot plug the charger into the scooter’s charging port, the charging port may be damaged. Check the prongs on the charging port to ensure they are straight, and clear the area of any debris. Consider replacing the charging port.
The Battery is Damaged
After long-term use, the battery will not hold as much charge and will eventually stop charging. Consider replacing the battery.
Scooter Will Power On But Will Not Move
The scooter will power on but fails to move when using the acceleration lever.
The Acceleration Lever is Stuck
First, examine the acceleration lever for any debris. Next, ensure acceleration lever has a free range of motion, checking for electrical buzzing or movement. If the acceleration lever seems unresponsive, it may be time to replace the acceleration lever.
The Motor is Unresponsive
The device’s interior motors are susceptible to damage. If your scooter is fully charged and powered on, the problem may be within the motors. Verify that the wheel has free range of motion and is not getting caught on debris. If the scooter is still not moving, the motors may need replacing.
Headlights Will Not Shine
The scooter’s headlights are dim or will not turn on.
Headlights Will Not Turn On
First, check behind the headlights for frayed, damaged wires and make sure all connections are secure. If you notice any damage on the headlight component replace the headlights.
Headlights are Dimmed
If your scooter’s headlights are dimmed, it is time to replace the headlights. The headlights grow weaker as the bulbs inside begin to burn out. Consider replacing the headlights.
Scooter Will Not Fold
The scooter is stuck in the upright position and will not collapse.
The Release Lever is Not Pulled
The release lever must be pulled before the scooter can collapse. The scooter has two folding positions: 45 degrees from the deck or parallel with the deck. Pull the release lever located near the base of the handlebar support beam until it rests in the slot closest to the scooter’s deck.
The Release Lever is Stuck
If the release lever is stuck, make sure there is no debris in the way. If the lever is still too hard to pull, consider applying lubricant to the lever closest to where it comes in contact with the scooter.
The Folding Hinge is Stuck
If the release lever is pulled and the scooter still will not fold, check the hinge for debris or rust. Apply lubricant to the hinges between the deck and handlebar support beam after pulling the release lever to fold the scooter.
Author
with
Cami Lowrey
450 Reputation
3 Guides authored
Cal Poly, Team S7-G2, Regan Winter 2020 Member of Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Members
60 Guides authored
12 Comments
In a small accident, the screen came off. It worked for a few minutes then the power shut off. I brought it home and charged it fully. Tried to turn it on and it would not power up. Thoughts?? Help??
Chad Collins - Reply Share
Just recieved my scooter a week and a half ago . Worked fine now when I turn it on front wheel won't move evwn with power. With no power it moves. Need a new motor already ????
Casey Wyatt - Reply Share
My scooter will not turn on
Tasheana Ricks - Reply Share
What is the color code layout for circuit board under gauge
Tom Riley - Reply Share
Scooter is stuck front wheel and handle bars will not move
Jennifer Palmquist - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 34
All Time: 4,737
