Hover-1 Rally Rear Wheel Replacement
  1. Hover-1 Rally Rear Wheel Replacement, Rear Wheel: step 1, image 1 of 1
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
    Ask FixBot
  2. Hover-1 Rally Rear Wheel Replacement: step 2, image 1 of 1
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
    Ask FixBot
  3. Hover-1 Rally Rear Wheel Replacement: step 3, image 1 of 2 Hover-1 Rally Rear Wheel Replacement: step 3, image 2 of 2
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
    Ask FixBot
  4. Hover-1 Rally Rear Wheel Replacement: step 4, image 1 of 1
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
    Ask FixBot
Cami Lowrey
450 Reputation
3 Guides authored
Cal Poly, Team S7-G2, Regan Winter 2020 Member of Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Members
7 Guides authored
1 Guide Comment
Where can I buy replacement tires/wheels for the hover-1 rally scooter?
Josh Hatt - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 45
All Time: 1,566
