Hover-1 Rally Headlight Replacement
    1. Hover-1 Rally Headlight Replacement, Headlight: step 1, image 1 of 2 Hover-1 Rally Headlight Replacement, Headlight: step 1, image 2 of 2
      • Remove four 5 mm screws with a 5 mm hex key.
      • When reinstalling, gently tighten each screw simultaneously to apply equal pressure on both sides of the casing.
      Ask FixBot
    2. Hover-1 Rally Headlight Replacement: step 2, image 1 of 1
      • Apply pressure to both ends of the headlight to remove it from the scooter.
      • Be gentle. You will feel some resistance due to the glue that is used.
      Ask FixBot
    3. Hover-1 Rally Headlight Replacement: step 3, image 1 of 1
      • Once the headlight is loose from the scooter, disconnect the two wires using a soldering iron.
      • Use this soldering guide for tips on using a soldering iron.
      Ask FixBot
Cami Lowrey
450 Reputation
3 Guides authored
Cal Poly, Team S7-G2, Regan Winter 2020 Member of Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 38
All Time: 939
