Phone Won't Turn On
Battery Not Charged
If the phone is not plugged in and the phone will not turn on, before opening the whole phone up, try plugging in the phone to see if the battery died and needs to be charged.
Battery Won't Hold A Charge
If the phone turns on when the device is plugged in, but won't charge and stay on without being plugged in, there is something wrong with the phone's battery, look at how to replace the battery.
Key's Don't work
Broken Keyboard
If a key has popped out or is broken, the keyboard needs to be replaced. See the repair guide for replacing the keyboard.
Broken Navigation Keys
If the keys used to navigate the phone are broken, follow the repair guide for replacing the keyboard to replace the navigation keys.
Motherboard Doesn't Register Keys
When a key is pressed and you receive the response of another key or no response at all there is something wrong with the motherboard. This might be due to a bad connection between the keys and the motherboard. Most likely the motherboard will need to be replaced.
Ear Speakers Won't Work
Broken Speakers
If you are not able to hear anything, for example, someone's voice of over the phone, the speakers may be broken. Most likely the speakers will need to be replaced.
Screen Disoriented
There Is A Crack In The Screen
If there is a line on the screen or part of the screen turns discolored, there is probably a crack on the screen and the screen needs to be replaced.
The Backlight Went Out
If the phone screen is extremely dark, but you can tell that there is still something on the screen, the backlight is out. For the backlight to be replaced, the LCD needs to be replaced.
Phone is Frozen
Broken Motherboard
If the phone turns on and does not respond, it has probably frozen and can most likely be because of a bad motherboard that might need replacing. First try turning it off, or taking out the battery to force it off. Then restart it, if it still isn't responsive, the motherboard needs replacing.
Corrupt Data
Faulty Motherboard
If you are incapable to find specific data (i.e. contacts, photos, etc), and after re-entering the information the phone persists omitting the data, the phone might have deleted the data due to a faulty hard drive on the motherboard that needs to be replaced. If you attempt to open a file and data comes up as corrupt or incomplete, this also is due to a faulty hard drive, so the motherboard needs to be replaced.
Author
with
obryanlp
49 Reputation
0 Guides authored
Cal Poly, Team 25-29, Garner Spring 2011 Member of Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 1,419
