HTC SMT 6175 Keyboard Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
100
All Time:
2,318
Comments: 0
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
If your HTC SMT 6175 keyboard and navigation keys aren't typing properly, due to malfunctioning or broken keys, then this guide can help you disassemble and replace the keyboard and navigation keys. The HTC SMT 6175 keyboard is the qwerty keyboard (soft keys) on the front of the phone. The navigation keys are the hard, directional keys above the qwerty keyboard.
Before you begin the repair, be sure to power off your phone and unplug it from the charger.
Tools
    1. HTC SMT 6175 Keyboard Replacement, Back Case: step 1, image 1 of 1
      • First, flip the phone over so that the back is facing upwards.
      Ask FixBot
    2. HTC SMT 6175 Keyboard Replacement: step 2, image 1 of 2 HTC SMT 6175 Keyboard Replacement: step 2, image 2 of 2
      • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
      Ask FixBot
    3. HTC SMT 6175 Keyboard Replacement, Battery: step 3, image 1 of 2 HTC SMT 6175 Keyboard Replacement, Battery: step 3, image 2 of 2
      • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
      Ask FixBot
    1. HTC SMT 6175 Keyboard Replacement, Keyboard: step 4, image 1 of 2 HTC SMT 6175 Keyboard Replacement, Keyboard: step 4, image 2 of 2
      • To remove the back casing inside the phone, remove the six screws around the perimeter.
      Ask FixBot
    2. HTC SMT 6175 Keyboard Replacement: step 5, image 1 of 2 HTC SMT 6175 Keyboard Replacement: step 5, image 2 of 2
      • Carefully pull off the back casing.
      • This step may be difficult. Start pulling the back out from the front shell. As it starts to lift up, move the phone side-to-side until the whole back is free.
      Ask FixBot
    3. HTC SMT 6175 Keyboard Replacement: step 6, image 1 of 2 HTC SMT 6175 Keyboard Replacement: step 6, image 2 of 2
      • Remove the top screw.
      • Be CAREFUL, because the LCD screen is attached to the front side of the motherboard by a flexible ribbon cable.
      Ask FixBot
    4. HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: step 7, image 1 of 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: step 7, image 2 of 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: step 7, image 3 of 3
      • Pull the plastic keyboard away from the front case.
      Ask FixBot
    5. HTC SMT 6175 Keyboard Replacement, Navigation Keys: step 8, image 1 of 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: step 8, image 2 of 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: step 8, image 3 of 3
      • To remove the navigation keys on the front of the phone, remove the four screws securing the navigation keys using a Phillips screwdriver.
      • Remove the navigation keys from the front of the phone.
      • They should pop out as a unit.
      Ask FixBot
Luke Plewa
116 Reputation
4 Guides authored
Cal Poly, Team 25-29, Garner Spring 2011 Member of Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 100
All Time: 2,318
