Phone is unresponsive or frozen
No matter what you do, you can't get your Android to respond to your commands .
Phone needs to be restarted
The phone may be powered off or needs to restart. To restart, hold the sleep/wake button down until the phone vibrates and screens brightens.
Low battery
If your Android won't turn respond, your phone may simply not have a charge. Plug it in to the charger for a small time and then hold the switch on.
Android will not charge
Even plugged in, the android won't charge. The charging light indicator does not turn on.
Wrong charging cord
Many charging cables look the same but are slightly different from each other. Check to make sure that the cord you are using is the same that came with your device or is a chord built specifically for that device.
NOTE: The HTC Incredible 2 is compatible with the original HTC Incredible charger.
Dirty/Damaged input ports
If it is the correct cord, it's input may be bent or dirty. Inspect it for bends or debris, then try again. If the device doesn't charge, it may have a bent or dirty input port. Check it as well, clean it if necessary. If it still won't' charge, then the port may be faulty and in need of repair or replacement.
Phone won't turn on
The charge light indicates full battery but won't turn on.
Dead battery
Even if left connected to a charger, the phone won't respond to restart or any frantic inputs. It may be a dead battery, incapable of accepting a charge, and will need replacement. To replace the battery, follow the Battery Replacement guide.
Power button misaligned/faulty
Even with a working battery, the phone will not start if the power button is misaligned or faulty. If misaligned, it can easily be removed then re-inserted. If faulty, then the piece can easily be replaced. To re-insert or replace the power button, follow the Power Button Replacement guide.
NOTE: The power button is also known as the wake/sleep button.
Volume controls are unresponsive
The volume controls are unresponsive or hyper-sensitive.
Sensitive controls
Sometimes when you want to change the volume, the volume "jumps" the intended setting and maxes out or minimizes to vibrate mode. This is unavoidable as the volume buttons are naturally very sensitive. Avoid holding the buttons down and resort to only tapping the button gently to arrive at the desired audible setting.
Volume button misaligned/faulty
If there is no change in volume, even if holding down or mashing the controls, then the buttons may be misaligned or faulty. If misaligned, they can easily be removed then re-inserted. If faulty, then the piece can easily be replaced. To re-insert or replace the volume button, refer to the Volume Button Replacement guide.
Memory filled to max capacity
"Installing new apps or downloads won't fit on allocated memory."
Memory re-allocation
It is possible to coax a little more memory from your device by moving data from the default space to the micro SD card. Go to your device settings (indicated by a gear icon). From there, scroll to applications, then click "Manage Applications". From there, you can click on an app and if it is not built-in to the phone, the you can move it to the card by pressing "Move to SD Card". If the app IS built in, then it is vital to how the phone naturally runs and cannot be moved.
Upgrading your memory
If you have filled up the available storage space on the micro SD card, then you may wish to consider installing a fresh card with a larger capacity. Save as much information as you can wirelessly, then remove the original micro SD card and replace it with another. To re-insert or replace the micro SD card, refer to the Micro SD Card Replacement guide.
Account/Internet access is blocked
"The phone cannot access your user data or connect to the Internet."
Account status check
If your data plan is fairly low, you can easily reach and exceed your allotted data by calling texting, or using the Internet. To solve this problem, contact your carrier to discuss upgrading your data plan to re-connect.
SIM card dismounted or missing
The SIM card is your account's "identification" on your phone. Moving a SIM card from phone to phone allows you to move your basic information (numbers, contacts, addresses, etc) and data plan to a new phone. If you cannot access your basic information or connect to the Internet, then the phone may not be reading a SIM card. It could be dismounted, faulty, or missing. To re-insert or replace the SIM card,refer to the SIM Card Replacement guide.
Author
with
Jonathan Morsch
394 Reputation
2 Guides authored
Cal Poly, Team 11-53, Amido Spring 2014 Member of Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 Members
84 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 2,328
