Up to 20% off select tools
HTC Incredible 2 Volume Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
95
All Time:
878
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Having trouble adjusting the phone's volume? This guide will walk you through the steps of how to access and replace the audio controls.
    1. HTC Incredible 2 Volume Button Replacement, Disassembling HTC Incredible 2 Back Panel: step 1, image 1 of 2 HTC Incredible 2 Volume Button Replacement, Disassembling HTC Incredible 2 Back Panel: step 1, image 2 of 2
      • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
      • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
      • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
      Ask FixBot
    2. HTC Incredible 2 Volume Button Replacement: step 2, image 1 of 1
      • Remove the rear panel from the phone.
      Ask FixBot
    1. HTC Incredible 2 Volume Button Replacement, Battery: step 3, image 1 of 1
      • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
      • Use a penny or dime if you can't use your fingernail.
      Ask FixBot
    2. HTC Incredible 2 Volume Button Replacement: step 4, image 1 of 2 HTC Incredible 2 Volume Button Replacement: step 4, image 2 of 2
      • Gently lever the battery up and away from the lights.
      • Lift the top of the battery up and remove the battery from the rear inner frame.
      Ask FixBot
    1. HTC Incredible 2 Volume Button Replacement, Mid Panel: step 5, image 1 of 1
      • Remove the seven 1.42 mm Torx T5 screws
      Ask FixBot
    2. HTC Incredible 2 Volume Button Replacement: step 6, image 1 of 2 HTC Incredible 2 Volume Button Replacement: step 6, image 2 of 2
      • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
      • Apply minimal pressure as the mid panel is very delicate.
      Ask FixBot
    3. HTC Incredible 2 Volume Button Replacement: step 7, image 1 of 1
      • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
      Ask FixBot
    1. HTC Incredible 2 Volume Button Replacement, Volume Button: step 8, image 1 of 3 HTC Incredible 2 Volume Button Replacement, Volume Button: step 8, image 2 of 3 HTC Incredible 2 Volume Button Replacement, Volume Button: step 8, image 3 of 3
      • Firmly grasp the volume button from the mid panel on the clip side
      • Gently lift the button upwards and remove it
      Ask FixBot
2 other people completed this guide.
Author
with
Robert Trujillo
246 Reputation
2 Guides authored
Cal Poly, Team 11-53, Amido Spring 2014 Member of Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 95
All Time: 878
