Up to 20% off select tools
HTC Incredible 2 Micro SD Card Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
97
All Time:
938
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Having memory issues? Replacing the SD memory card is quick and painless.
    1. HTC Incredible 2  Micro SD Card Replacement, Disassembling HTC Incredible 2 Back Panel: step 1, image 1 of 2 HTC Incredible 2  Micro SD Card Replacement, Disassembling HTC Incredible 2 Back Panel: step 1, image 2 of 2
      • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
      • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
      • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
      Ask FixBot
    2. HTC Incredible 2  Micro SD Card Replacement: step 2, image 1 of 1
      • Remove the rear panel from the phone.
      Ask FixBot
    1. HTC Incredible 2  Micro SD Card Replacement, Micro SD Card: step 3, image 1 of 2 HTC Incredible 2  Micro SD Card Replacement, Micro SD Card: step 3, image 2 of 2
      • Use your fingertip to push inward on the SD card until you hear a click.
      Ask FixBot
    2. HTC Incredible 2  Micro SD Card Replacement: step 4, image 1 of 3 HTC Incredible 2  Micro SD Card Replacement: step 4, image 2 of 3 HTC Incredible 2  Micro SD Card Replacement: step 4, image 3 of 3
      • Remove your finger. The SD card is no longer being held in place.
      • Grasp it with two fingers and pull it towards you to remove it.
      Ask FixBot
Author
with
Ka Tong
131 Reputation
1 Guide authored
Cal Poly, Team 11-53, Amido Spring 2014 Member of Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 97
All Time: 938
