HTC Incredible 2 Battery Replacement
    1. HTC Incredible 2 Battery Replacement, Disassembling HTC Incredible 2 Back Panel: step 1, image 1 of 2 HTC Incredible 2 Battery Replacement, Disassembling HTC Incredible 2 Back Panel: step 1, image 2 of 2
      • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
      • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
      • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
      Ask FixBot
    2. HTC Incredible 2 Battery Replacement: step 2, image 1 of 1
      • Remove the rear panel from the phone.
      Ask FixBot
    1. HTC Incredible 2 Battery Replacement, Battery: step 3, image 1 of 1
      • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
      • Use a penny or dime if you can't use your fingernail.
      Ask FixBot
    2. HTC Incredible 2 Battery Replacement: step 4, image 1 of 2 HTC Incredible 2 Battery Replacement: step 4, image 2 of 2
      • Gently lever the battery up and away from the lights.
      • Lift the top of the battery up and remove the battery from the rear inner frame.
      Ask FixBot
2 other people completed this guide.
Jonathan Morsch
394 Reputation
2 Guides authored
Cal Poly, Team 11-53, Amido Spring 2014 Member of Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 100
All Time: 1,037
