Laptop Will Not Turn On
The power button refuses to cooperate.
Dead Battery
  • Run the laptop with the battery only. If it begins to power on and then shuts off, this is a problem with the laptop booting.
  • Try to run the laptop by plugging in the power adapter and removing the battery entirely. Use this guide to aid in removing the battery.
Faulty Adapter
Your adapter may be broken, which would cause no power to reach the laptop or battery.
  • Check if power is running through the adapter by using a voltmeter on the laptop-side plug.
  • Borrow a friend's adapter and see if your laptop powers on.
The Display is Malfunctioning
Flickering, entirely black, or discolored, the display is unreadable or very annoying.
Backlight Is Off
Sometimes the backlight is simply turned off, but other times it becomes unplugged or fails entirely warranting a replacement.
  • Make sure the backlight is on by clicking the start button, clicking the Control Panel, then going to Power Options and ensure the slider on the bottom of the screen is not all the way to the left.
  • Shine a flashlight on the screen, if you can see your desktop or program, but it is really dark, your backlight is off or broken. Follow this guide to replace your display.
Pixels are Discolored
If there are single pixels or whole lines of pixels that are unresponsive, your LCD panel is broken and needs to be replaced.
Touchpad Isn't Responding Correctly
The touchpad is oversensitive, insensitive, or doesn't work at all.
Ultra-Sensitive
Software may be causing the touchpad to behave incorrectly. Open the Mouse section of your Control Panel and adjust the tracking. If this fails there is likely a hardware problem with your touch.
The Touchpad Is Disabled
The laptop has a toggle that can disable the touchpad. You can attempt to re-enable it by pressing the small rectangular shaped button above the touchpad. If this fails, there may be a bad connection inside your laptop or it may need to be replaced.
Laptop Overheats
The computer runs very hot under normal operation.
Blocked Air Vents
Check the air vents around the dv5-1125nr for dust blockage. If there is a noticeable buildup of dirt, use a can of compressed air to clear out the dirt.
Dead Fan
Check to see if the fans are running by putting your ear up against the keyboard. If there isn't any noticeable noise, a fan may be dead. Follow this guide.
The Keyboard Won't Respond
Word processing just reached a whole new level of extreme.
The Keys Are Stuck
If keys are stuck you may be able to un-stick them using a plastic spludger tool. If unsuccessful, follow this guide to replace a broken keyboard.
The Keyboard Doesn't Respond
It is possible that the problem is software related. Try booting using a Windows install CD. Otherwise, check out the keyboard replacement guide.
Laptop won't boot
The laptop turns on but cannot reach the operating system.
Hard drive failure
The most likely cause of not booting is a damaged hard drive. Make sure you have a backup of your files, then follow this hard drive replacement guide.
RAM failure
If your computer doesn't even show any graphics, then it is likely you have a RAM failure. Luckily, RAM is very easy to replace. Follow this guide to replace your RAM.
Nick Loey
1,715 Reputation
8 Guides authored
Cal Poly, Team 9-15, Regan Spring 2014 Member of Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Members
120 Guides authored
2 Comments
My Hp pavilion dv5 1215ee is not turning on , I plugged the charger ,near the charger port the light is turn on and I pressed power button, not powering on, no lights , only charger light.
Mosaic Wolf Tech - Reply Share
it may be a blown Mosfet. Try seeein how far the 19V go on main rail. (see youtube).
ediflorianUS - Reply Share
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 44
All Time: 1,846
