HP dv5-1125nr Display Replacement
    1. HP dv5-1125nr Display Replacement, Battery: step 1, image 1 of 1
      • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
      • Slide the switch to the left until the release clicks.
      Ask FixBot
    2. HP dv5-1125nr Display Replacement: step 2, image 1 of 1
      • Remove the battery.
      • The release switch may need to be held down while removing the battery.
      Ask FixBot
    1. HP dv5-1125nr Display Replacement, Hard Drive: step 3, image 1 of 2 HP dv5-1125nr Display Replacement, Hard Drive: step 3, image 2 of 2
      • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP dv5-1125nr Display Replacement: step 4, image 1 of 1
      • Remove the plastic hard drive cover.
      Ask FixBot
    3. HP dv5-1125nr Display Replacement: step 5, image 1 of 2 HP dv5-1125nr Display Replacement: step 5, image 2 of 2
      • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
      Ask FixBot
    4. HP dv5-1125nr Display Replacement: step 6, image 1 of 2 HP dv5-1125nr Display Replacement: step 6, image 2 of 2
      • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
      Ask FixBot
    5. HP dv5-1125nr Display Replacement: step 7, image 1 of 2 HP dv5-1125nr Display Replacement: step 7, image 2 of 2
      • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
      • Slide the hard drive out of the enclosure to complete the removal process.
      Ask FixBot
    1. HP dv5-1125nr Display Replacement, RAM: step 8, image 1 of 1
      • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP dv5-1125nr Display Replacement: step 9, image 1 of 2 HP dv5-1125nr Display Replacement: step 9, image 2 of 2
      • Remove the RAM cover to reveal the module's underneath.
      Ask FixBot
    3. HP dv5-1125nr Display Replacement: step 10, image 1 of 3 HP dv5-1125nr Display Replacement: step 10, image 2 of 3 HP dv5-1125nr Display Replacement: step 10, image 3 of 3
      • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
      • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
      • Once the module is released, gently pull the module upwards.
      • Repeat for the RAM module underneath the first one.
      Ask FixBot
    1. HP dv5-1125nr Display Replacement, Keyboard: step 11, image 1 of 1
      • Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
      Ask FixBot
    2. HP dv5-1125nr Display Replacement: step 12, image 1 of 1
      • Remove the five remaining 2mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. HP dv5-1125nr Display Replacement: step 13, image 1 of 1
      • Unscrew the 4mm Phillips screw inside the hard drive bay.
      • Make sure to keep track of which screw goes where. The sizes are different for each set of screws!
      Ask FixBot
    4. HP dv5-1125nr Display Replacement: step 14, image 1 of 2 HP dv5-1125nr Display Replacement: step 14, image 2 of 2
      • Locate the hole in between the hard drive and RAM compartments.
      • The hole is marked by a small keyboard symbol in the plastic (see the second picture).
      • Unscrew the 4mm Phillips head screw from this hole.
      Ask FixBot
    5. HP dv5-1125nr Display Replacement: step 15, image 1 of 2 HP dv5-1125nr Display Replacement: step 15, image 2 of 2
      • Flip the laptop, and use the plastic opening tool on the side seam to remove the top cover.
      • You may need to use the opening tool on both sides of the cover.
      • Be careful not to break the ribbon cables under the cover.
      Ask FixBot
    6. HP dv5-1125nr Display Replacement: step 16, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
      Ask FixBot
    7. HP dv5-1125nr Display Replacement: step 17, image 1 of 1
      • Dislodge the keyboard to access the underside.
      • Do not fully remove the keyboard. It is still attached by a ribbon cable, and forceful removal could break this necessary connection.
      Ask FixBot
    8. HP dv5-1125nr Display Replacement: step 18, image 1 of 2 HP dv5-1125nr Display Replacement: step 18, image 2 of 2
      • Locate the ribbon cable connection between the keyboard and motherboard.
      • Pull upwards on the small black bar to release the ribbon cable and remove it.
      • Do not yank on the ribbon or try to pull it out. This may break the cable or motherboard.
      Ask FixBot
    9. HP dv5-1125nr Display Replacement: step 19, image 1 of 1
      • The keyboard is now ready for replacement.
      Ask FixBot
    1. HP dv5-1125nr Display Replacement, Display: step 20, image 1 of 3 HP dv5-1125nr Display Replacement, Display: step 20, image 2 of 3 HP dv5-1125nr Display Replacement, Display: step 20, image 3 of 3
      • Locate four 3mm screws in the upper corners of the keyboard tray and remove them using a #00 Phillips screwdriver.
      Ask FixBot
    2. HP dv5-1125nr Display Replacement: step 21, image 1 of 2 HP dv5-1125nr Display Replacement: step 21, image 2 of 2
      • Locate the two ribbon cable connectors that attach the speaker assembly to the motherboard.
      • Using your fingers, carefully detach the ribbon cables from the motherboard by pulling them straight out on the connector.
      Ask FixBot
    3. HP dv5-1125nr Display Replacement: step 22, image 1 of 1
      • Remove the speaker assembly from the keyboard tray.
      Ask FixBot
    4. HP dv5-1125nr Display Replacement: step 23, image 1 of 1
      • Locate the large display ribbon connector near the upper left corner of the keyboard tray and remove the ribbon by pulling straight out on the connector.
      Ask FixBot
    5. HP dv5-1125nr Display Replacement: step 24, image 1 of 1
      • The display should now be loose, but make sure to remove all ribbon connectors before attempting to take off the display.
      • Locate the two final ribbon connectors for the display on the motherboard and remove them similarly by pulling straight outward on the connectors.
      • You are now free to remove the display from the computer.
      Ask FixBot
12 other people completed this guide.
Nick Loey
1,715 Reputation
8 Guides authored
Cal Poly, Team 9-15, Regan Spring 2014 Member of Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Members
120 Guides authored
1 Guide Comment
Where can i buy the display?
Fabio Benedetti - Reply Share
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 108
All Time: 4,690
