HP dv5-1125nr RAM Replacement
    1. HP dv5-1125nr RAM Replacement, Battery: step 1, image 1 of 1
      • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
      • Slide the switch to the left until the release clicks.
      Ask FixBot
    2. HP dv5-1125nr RAM Replacement: step 2, image 1 of 1
      • Remove the battery.
      • The release switch may need to be held down while removing the battery.
      Ask FixBot
    1. HP dv5-1125nr RAM Replacement, RAM: step 3, image 1 of 1
      • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP dv5-1125nr RAM Replacement: step 4, image 1 of 2 HP dv5-1125nr RAM Replacement: step 4, image 2 of 2
      • Remove the RAM cover to reveal the module's underneath.
      Ask FixBot
    3. HP dv5-1125nr RAM Replacement: step 5, image 1 of 3 HP dv5-1125nr RAM Replacement: step 5, image 2 of 3 HP dv5-1125nr RAM Replacement: step 5, image 3 of 3
      • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
      • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
      • Once the module is released, gently pull the module upwards.
      • Repeat for the RAM module underneath the first one.
      Ask FixBot
4 other people completed this guide.
Nick Loey
1,715 Reputation
8 Guides authored
Cal Poly, Team 9-15, Regan Spring 2014 Member of Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 105
All Time: 1,521
