HP dv5-1125nr Keyboard Replacement
    1. HP dv5-1125nr Keyboard Replacement, Battery: step 1, image 1 of 1
      • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
      • Slide the switch to the left until the release clicks.
      Ask FixBot
    2. HP dv5-1125nr Keyboard Replacement: step 2, image 1 of 1
      • Remove the battery.
      • The release switch may need to be held down while removing the battery.
      Ask FixBot
    1. HP dv5-1125nr Keyboard Replacement, Hard Drive: step 3, image 1 of 2 HP dv5-1125nr Keyboard Replacement, Hard Drive: step 3, image 2 of 2
      • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP dv5-1125nr Keyboard Replacement: step 4, image 1 of 1
      • Remove the plastic hard drive cover.
      Ask FixBot
    3. HP dv5-1125nr Keyboard Replacement: step 5, image 1 of 2 HP dv5-1125nr Keyboard Replacement: step 5, image 2 of 2
      • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
      Ask FixBot
    4. HP dv5-1125nr Keyboard Replacement: step 6, image 1 of 2 HP dv5-1125nr Keyboard Replacement: step 6, image 2 of 2
      • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
      Ask FixBot
    5. HP dv5-1125nr Keyboard Replacement: step 7, image 1 of 2 HP dv5-1125nr Keyboard Replacement: step 7, image 2 of 2
      • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
      • Slide the hard drive out of the enclosure to complete the removal process.
      Ask FixBot
    1. HP dv5-1125nr Keyboard Replacement, RAM: step 8, image 1 of 1
      • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP dv5-1125nr Keyboard Replacement: step 9, image 1 of 2 HP dv5-1125nr Keyboard Replacement: step 9, image 2 of 2
      • Remove the RAM cover to reveal the module's underneath.
      Ask FixBot
    3. HP dv5-1125nr Keyboard Replacement: step 10, image 1 of 3 HP dv5-1125nr Keyboard Replacement: step 10, image 2 of 3 HP dv5-1125nr Keyboard Replacement: step 10, image 3 of 3
      • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
      • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
      • Once the module is released, gently pull the module upwards.
      • Repeat for the RAM module underneath the first one.
      Ask FixBot
    1. HP dv5-1125nr Keyboard Replacement, Keyboard: step 11, image 1 of 1
      • Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
      Ask FixBot
    2. HP dv5-1125nr Keyboard Replacement: step 12, image 1 of 1
      • Remove the five remaining 2mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. HP dv5-1125nr Keyboard Replacement: step 13, image 1 of 1
      • Unscrew the 4mm Phillips screw inside the hard drive bay.
      • Make sure to keep track of which screw goes where. The sizes are different for each set of screws!
      Ask FixBot
    4. HP dv5-1125nr Keyboard Replacement: step 14, image 1 of 2 HP dv5-1125nr Keyboard Replacement: step 14, image 2 of 2
      • Locate the hole in between the hard drive and RAM compartments.
      • The hole is marked by a small keyboard symbol in the plastic (see the second picture).
      • Unscrew the 4mm Phillips head screw from this hole.
      Ask FixBot
    5. HP dv5-1125nr Keyboard Replacement: step 15, image 1 of 2 HP dv5-1125nr Keyboard Replacement: step 15, image 2 of 2
      • Flip the laptop, and use the plastic opening tool on the side seam to remove the top cover.
      • You may need to use the opening tool on both sides of the cover.
      • Be careful not to break the ribbon cables under the cover.
      Ask FixBot
    6. HP dv5-1125nr Keyboard Replacement: step 16, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
      Ask FixBot
    7. HP dv5-1125nr Keyboard Replacement: step 17, image 1 of 1
      • Dislodge the keyboard to access the underside.
      • Do not fully remove the keyboard. It is still attached by a ribbon cable, and forceful removal could break this necessary connection.
      Ask FixBot
    8. HP dv5-1125nr Keyboard Replacement: step 18, image 1 of 2 HP dv5-1125nr Keyboard Replacement: step 18, image 2 of 2
      • Locate the ribbon cable connection between the keyboard and motherboard.
      • Pull upwards on the small black bar to release the ribbon cable and remove it.
      • Do not yank on the ribbon or try to pull it out. This may break the cable or motherboard.
      Ask FixBot
    9. HP dv5-1125nr Keyboard Replacement: step 19, image 1 of 1
      • The keyboard is now ready for replacement.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reinserting the ribbon cable, it should click into place.
2 other people completed this guide.
Nick Loey
1,715 Reputation
8 Guides authored
Cal Poly, Team 9-15, Regan Spring 2014 Member of Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 89
All Time: 2,971
