Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Power Button Doesn't Work
The laptop will not activate when the power button is pushed.
Power Cable not Plugged In
If the laptop is not responding to the power button, it may be out of charge. In this case, connect the laptop to the charging cable and wait at least 30 minutes before attempting to press the power button again.
Faulty Power Cord
If the laptop still does not respond to the power button, there may be an issue with the power cable, inspect the cable for any frayed wires or loose connections. These may be indicators that the power cable is faulty and would need replacing.
Faulty Battery
If the power cable seems to be intact and not damaged, there may be an issue with the battery, this could also be the case if the laptop runs with the power cable plugged in but does not turn on without the power cable. In these cases, the battery may need replacing. For help replacing the battery click here
Laptop Running Slow
When running multiple programs at once such as an internet browser and Microsoft Word, everything runs really slow and takes a long time to load in.
Too Many Unnecessary Programs Open
Some computers simply don't have the ability to handle a large amount of tasks at once. This is only an issue in cases where a very large amount of programs are open at the same time. In this case, simply close any unnecessary programs and see if the computer begins to run faster.
Faulty Ram
If the above step fails to fix computer sluggishness, or if the computer suddenly failed to handle as many tasks as it was able to beforehand, there may be a faulty RAM card. In this case, one or more of the RAM cards has possibly failed and would need replacing. For help in replacing the RAM click here
Laptop Can't Save Any New Data
When you go to save something such as a file or picture the laptop is unable to store it.
Too Much Data
To determine whether or not there isn't enough space on the hard drive, click on "My Computer" on the desktop, and in the window, look at your hard drive. If the bar is red and full then there may not be enough storage for additional data. If there isn't enough storage space left on the hard drive, empty the recycling bin as that will free up space. Next is to remove any unnecessary data; a tool that may assist with this is an external hard drive, as some data could be ported to that and provide you with more storage in your laptop.
Internal Hard Drive Too Small
If these are not viable options or do not free up enough space, it may be necessary to purchase a hard drive with more storage space and replace the current one. For help on replacing the current hard drive click here
Trouble Connecting to the Internet
Your laptop won't connect to the WiFi.
Reset the Router
One of the major causes of WiFi problems is the router, and it should always be the first place to look before replacing any parts. The easiest way to attempt to fix a router is to simply unplug it from power, and wait 5 minutes before plugging it back in. This will reset the router so that it hopefully finds your laptop.
WiFi Not Enabled
Make sure that WiFi is enabled on the laptop, as this may have been disabled by accident at some point. Press the Fn + F2 keys at the same time, and allow the computer to scan for approximately 30 seconds.
Faulty Wireless Card
If there are still issues connecting to WiFi, or the WiFi is irregularly slow, there may be an issue with the wireless card. In this case it may be necessary to replace the wireless card. For help replacing the wireless card click here
Buttons on the Keyboard Don't Work
The keys on the keyboard don't respond when they are pressed.
Dirty Keyboard
The keyboard may simply be dirty, or there may be debris under the keys. In this case, make sure the laptop is fully turned off, and tilt it so the keyboard is vertical. Then simply shake the laptop very gently while looking to see if any particles drop out. Another solution would be to used a compressed air can to blow out any debris.
Debris Under one Key
If one key specifically is not responding, or if it feels like there is an object underneath it when pressed, the key may need to be removed. In this case, simply use a plastic spudger to gently remove the key from the keyboard. Then either use compressed air, or the method above, to remove the debris.
Faulty Keyboard
If there is no debris under the keyboard, or if the keyboard completely does not respond, the keyboard may need to be replaced. For help replacing the keyboard click here
Fan Issues
Laptop is overheating, shutting down suddenly and making a very loud whirling noise
Laptop Shuts Down Suddenly
If the laptop is shutting down suddenly, there may be an overheating issue. To test this, feel the underside of the laptop; if the bottom is extremely hot it may be overheating. This is often caused by dust being trapped inside of the fan. To fix this, take a can of compressed air and blow it into the fan grates on the side of the laptop.
Dirty Fan
If the laptop is making a constant whirling noise, the fan may be working more than it otherwise should be. This is also often caused by dust inside the fan. To fix this, take a can of compressed air and blow it into the fan grates on the side of the laptop.
Author
with
Angela Pavadore
101 Reputation
0 Guides authored
1 Comment
My company 515 is not booting up
What should I do ??
Famuyiwa Olamide - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 821
