Up to 20% off select tools
HP Compaq 515 Keyboard Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
61
All Time:
951
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Removing the keyboard takes some patience but it isn't outrageously difficult. The only tools needed for this replacement guide are the PH1 screwdriver bit and the plastic spudger. Make sure to keep the two screws that are removed in a safe place so you don't lose them. Make sure the device is off before starting this guide. Be careful to not be too aggressive with the keyboard, it does take some force to separate it from the rest of the device but try to still be as gentle as possible.
    1. HP Compaq 515 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Turn the laptop over, the screws for the keyboard are in the middle and left of the device
      Ask FixBot
    2. HP Compaq 515 Keyboard Replacement: step 2, image 1 of 1
      • Unscrew the two 0.725 cm Screws with a PH1 screwdriver bit
      • Make sure to put the screws in a safe place so you don't lose them
      Ask FixBot
    3. HP Compaq 515 Keyboard Replacement: step 3, image 1 of 1
      • Flip the laptop over and open the screen
      Ask FixBot
    4. HP Compaq 515 Keyboard Replacement: step 4, image 1 of 2 HP Compaq 515 Keyboard Replacement: step 4, image 2 of 2
      • Gently use a plastic spudger to remove the plastic holder at the top of the keyboard
      Ask FixBot
    5. HP Compaq 515 Keyboard Replacement: step 5, image 1 of 1
      • Gently use a plastic spudger to remove the keyboard from its holders
      • Be careful as there is a wire connecting the keyboard to the laptop
      Ask FixBot
    6. HP Compaq 515 Keyboard Replacement: step 6, image 1 of 1
      • Carefully unclip and remove the large black wire that is connecting the keyboard to the laptop
      Ask FixBot
Author
with
Kirsten Harnden
259 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 61
All Time: 951
