Up to 20% off select tools
HP Compaq 515 Wireless Card Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
54
All Time:
746
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Removing the wireless card takes some focus but it isn't very difficult. The only tool needed for this replacement guide is the PH00 bit. Don't worry about losing the first two screws that get unscrewed because they are attached to the device for your convenience. The two 0.4 cm screws are not attached to the device so make sure to put them in a safe place. Make sure the device is off before starting this guide. The Hard Drive Replacement Guide is a prerequisite to this guide so be familiar with that guide before beginning.
    1. HP Compaq 515 Wireless Card Replacement, Hard Drive: step 1, image 1 of 1
      • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
      Ask FixBot
    2. HP Compaq 515 Wireless Card Replacement: step 2, image 1 of 1
      • Unscrew the two screws with a PH00 bit. This releases the hard drive.
      • The screws are held in place, so there is no need to worry about losing them
      Ask FixBot
    3. HP Compaq 515 Wireless Card Replacement: step 3, image 1 of 1
      • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
      Ask FixBot
    1. HP Compaq 515 Wireless Card Replacement, Wireless Card: step 4, image 1 of 1
      • The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
      Ask FixBot
    2. HP Compaq 515 Wireless Card Replacement: step 5, image 1 of 1
      • Unscrew the two screws holding the hard drive in place, using a PH00 bit.
      Ask FixBot
    3. HP Compaq 515 Wireless Card Replacement: step 6, image 1 of 2 HP Compaq 515 Wireless Card Replacement: step 6, image 2 of 2
      • Slide the wireless card backing towards you to remove it from the laptop.
      Ask FixBot
    4. HP Compaq 515 Wireless Card Replacement: step 7, image 1 of 1
      • Gently remove the black and white wires that are connected to the wireless card.
      • The wires are held firmly in place, so it may take some force to remove them. Be cautious when doing so as the wires may tear or fray
      Ask FixBot
    5. HP Compaq 515 Wireless Card Replacement: step 8, image 1 of 1
      • Remove the two .4 cm screws with a PH00 bit.
      Ask FixBot
Author
with
Aleks B
337 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 54
All Time: 746
