Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
HP 7 1800 won't turn on
No matter what you do, you can't get your HP 7 1800 to turn on.
Power Button Not Responding
Before taking apart your HP 7 1800, make sure to hold down the power button for a few seconds. If you do not hear an audible click, the power button may need replacement. If you did hear a click and the device still does not turn on, read on.
Incorrectly Installed Battery
By following our guide, make sure the battery is correctly installed to the motherboard. You may need a little force when inserting it to make sure all the pins are making contact with the motherboard.
Drained Battery
First try charging the battery. If your HP 7 1800 still won't turn on, you may have a bad battery that cannot hold a charge. Use our guide to replace your battery.
Broken Display/No Image
It is possible that it appears nothing is happening because the display is bad. If you connect the HP 7 1800 to your computer and the computer recognizes the device, it is possible the display is bad and must be replaced.
Faulty Motherboard
If everything is connected properly to the motherboard and the device is still not working properly, the problem most likely lies in the motherboard. Follow our simple guide to replace the motherboard.
No Audio or Distorted Audio
Your tablet turns on and appears to work (and you have the volume set to an appropriate level), but when you plug in headphones or use the built in speaker, the audio does not play properly.
Headphones Don't Produce Sound
Narrow the problem to the tablet by testing the plugged in headphones on another device. If the headphones work, then it is possible there is a problem with the audio jack.
Loose Audio Jack
First do a factory reset on the tablet to make sure the problem is not a software related issue. If that does not work, you will need to check the connection of the audio jack to the motherboard. If the audio jack connection is loose, it may need to be re-soldered. If re-soldering the audio jack did not fix the problem, you may need to replace it by following our guide.
Crackling Noise/No Sound From Speaker
If you do not have anything in the audio jack and sound is not working or crackling, the speaker may need to be re-soldered to the motherboard as it may have came loose. If re-soldering the the speaker does not work, you may need to replace the speaker.
Video is Distorted
Image on the tablet is distorted or pixels are burnt out.
Burnt Out or Stuck Pixels
If you notice burnt out or stuck pixels, try a pixel repair video such as this one. *****WARNING: THIS VIDEO CONTAINS FLASHING LIGHTS WHICH MAY NOT BE SUITABLE FOR THOSE WITH PHOTOSENSITIVE EPILEPSY***** If this does not fix the pixels, you may need to replace the display.
Display Flickers, Appears Blurry or Changes to Incorrect Colors
If you notice distortion or if you have already tried to refresh your pixels with the video without success, then you must replace the display (screen and digitizer).
Faulty Motherboard
If replacing the display did not work, and it is properly connected to the motherboard, your motherboard may need replacement.
Touch Screen Not Responding
No matter what you do to your tablet, and you're not wearing gloves or have dirty hands, the touch screen does not respond to touch input.
Unresponsive Touch Screen
If the touch screen is not responding, the front panel (which includes the touch screen and digitizer) may need to be replaced. Use our guide for an easy way to replace the display.
Faulty Motherboard
If replacing the front panel does not restore touch input, and it is correctly connected, the motherboard must be replaced.
Buttons Don't Work
After numerous tries pressing the buttons, there is no response from the device.
Broken/Stuck Buttons
If you press the buttons (volume or power) and they do not make a clicking noise, you may need to clean or replace the plastic buttons by following our guide.
Faulty Motherboard
Verify that the 3 black circular buttons are seated properly to the motherboard. If you press the buttons (volume or power) and they make a clicking noise, or you have already replaced them, then the motherboard may require replacement.
Front Facing Camera not Working
No matter what you do, the front facing camera does not work.
Lens is Damaged
If your images turn out blurry or discolored, your lens may be broken. If after dismantling the tablet and confirming the lens is damaged, you may need to take it in for repair or use our guide to replace the camera.
The Camera Application Shows a Blank Screen/Force Closes Upon Opening
If every application that uses the front facing camera force closes or the camera doesn't display an image, you may need to replace the front facing camera.
Faulty Motherboard
Check to make sure the camera is connected securely to the motherboard. If replacing the front facing camera does not solve the problem, you must replace the motherboard.
Author
with
Jonathan Valencia
1 Reputation
0 Guides authored
USF Tampa, Team 4-1, Brown Winter 2015 Member of USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Members
84 Guides authored
1 Comment
My HP 7 1800 will open normal apps but won't open games such as Vegas slots it force closes it immediately
Joe Halverson - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 32
All Time: 4,389
