Up to 20% off select tools
HP 7 1800 Display Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
92
All Time:
2,555
Comments: 2
2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide requires you to take apart nearly the entire tablet to get to the display. Be sure to keep track of the screws.
    1. HP 7 1800 Display Replacement, Remove the back panel: step 1, image 1 of 2 HP 7 1800 Display Replacement, Remove the back panel: step 1, image 2 of 2
      • Carefully insert a Spudger into one of the corners of the tablet.
      • Slide the Spudger along the edge popping the tabs out along the way.
      • Be careful not to break the tabs.
      Ask FixBot
    2. HP 7 1800 Display Replacement, Remove the battery: step 2, image 1 of 3 HP 7 1800 Display Replacement, Remove the battery: step 2, image 2 of 3 HP 7 1800 Display Replacement, Remove the battery: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Slide the Spudger under the battery to lift it off the adhesive.
      • Gently pull the cable connection from the motherboard using tweezers.
      Ask FixBot
    1. HP 7 1800 Display Replacement, Remove the large ribbon cable: step 3, image 1 of 2 HP 7 1800 Display Replacement, Remove the large ribbon cable: step 3, image 2 of 2
      Buy
      • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
      Ask FixBot
    2. HP 7 1800 Display Replacement, Remove the smaller ribbon cable: step 4, image 1 of 2 HP 7 1800 Display Replacement, Remove the smaller ribbon cable: step 4, image 2 of 2
      • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
      Ask FixBot
    3. HP 7 1800 Display Replacement, Unscrew the 7 silver screws from the logic board: step 5, image 1 of 1
      • Remove the following 7 screws:
      • Six 4.17mm Phillips #00 around the motherboard.
      • One 2.67mm Phillips #00 next to the front facing camera.
      • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
      Ask FixBot
    4. HP 7 1800 Display Replacement, Unplug the front facing camera from the logic board: step 6, image 1 of 1
      • Gently pry the front facing camera plug up and off of the motherboard.
      Ask FixBot
    5. HP 7 1800 Display Replacement, Remove the logic board: step 7, image 1 of 1
      • Carefully lift the motherboard directly up.
      Ask FixBot
    1. HP 7 1800 Display Replacement, Remove the ribbon cable attached to the metal plate: step 8, image 1 of 2 HP 7 1800 Display Replacement, Remove the ribbon cable attached to the metal plate: step 8, image 2 of 2
      • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
      Ask FixBot
    2. HP 7 1800 Display Replacement, Unscrew the 7 black screws on the metal plate: step 9, image 1 of 1
      • Unscrew the following black screws:
      • Seven 2.82mm Phillips #00 around the metal casing.
      Ask FixBot
    3. HP 7 1800 Display Replacement, Remove the metal plate: step 10, image 1 of 1
      • Gently lift the metal plate directly up.
      Ask FixBot
    4. HP 7 1800 Display Replacement, Remove the display: step 11, image 1 of 1
      • Gently lift the display directly up.
      Ask FixBot
5 other people completed this guide.
Author
with
TMD
792 Reputation
5 Guides authored
USF Tampa, Team 4-1, Brown Winter 2015 Member of USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Members
84 Guides authored
2 Guide Comments
I have this same tablet but I cannot find a replacement screen. Do you know where I could find one?
Karen Porter - Reply Share
I have the same problem
akiel panchan - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 92
All Time: 2,555
