HP 7 1800 Speaker Replacement
    1. HP 7 1800 Speaker Replacement, Remove the back panel: step 1, image 1 of 2 HP 7 1800 Speaker Replacement, Remove the back panel: step 1, image 2 of 2
      • Carefully insert a Spudger into one of the corners of the tablet.
      • Slide the Spudger along the edge popping the tabs out along the way.
      • Be careful not to break the tabs.
      Ask FixBot
    2. HP 7 1800 Speaker Replacement, Remove the battery: step 2, image 1 of 3 HP 7 1800 Speaker Replacement, Remove the battery: step 2, image 2 of 3 HP 7 1800 Speaker Replacement, Remove the battery: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Slide the Spudger under the battery to lift it off the adhesive.
      • Gently pull the cable connection from the motherboard using tweezers.
      Ask FixBot
    1. HP 7 1800 Speaker Replacement, Desolder the speaker wires: step 3, image 1 of 1
      • Desolder the two leads of the speaker wire that are connected to the motherboard.
      Ask FixBot
    2. HP 7 1800 Speaker Replacement, Remove the speaker: step 4, image 1 of 1
      Buy
      • Using tweezers, gently pull the speaker off of the metal plate.
      • The speaker is held onto the metal plate with light adhesive. It will require a little force to peel off.
      Ask FixBot
TMD
792 Reputation
5 Guides authored
USF Tampa, Team 4-1, Brown Winter 2015 Member of USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 90
All Time: 637
