HP 7 1800 Motherboard Replacement
    1. HP 7 1800 Motherboard Replacement, Remove the back panel: step 1, image 1 of 2 HP 7 1800 Motherboard Replacement, Remove the back panel: step 1, image 2 of 2
      • Carefully insert a Spudger into one of the corners of the tablet.
      • Slide the Spudger along the edge popping the tabs out along the way.
      • Be careful not to break the tabs.
      Ask FixBot
    2. HP 7 1800 Motherboard Replacement, Remove the battery: step 2, image 1 of 3 HP 7 1800 Motherboard Replacement, Remove the battery: step 2, image 2 of 3 HP 7 1800 Motherboard Replacement, Remove the battery: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Slide the Spudger under the battery to lift it off the adhesive.
      • Gently pull the cable connection from the motherboard using tweezers.
      Ask FixBot
    1. HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: step 3, image 1 of 2 HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: step 3, image 2 of 2
      Buy
      • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
      Ask FixBot
    2. HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: step 4, image 1 of 2 HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: step 4, image 2 of 2
      • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
      Ask FixBot
    3. HP 7 1800 Motherboard Replacement, Unscrew the 7 silver screws from the logic board: step 5, image 1 of 1
      • Remove the following 7 screws:
      • Six 4.17mm Phillips #00 around the motherboard.
      • One 2.67mm Phillips #00 next to the front facing camera.
      • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
      Ask FixBot
    4. HP 7 1800 Motherboard Replacement, Unplug the front facing camera from the logic board: step 6, image 1 of 1
      • Gently pry the front facing camera plug up and off of the motherboard.
      Ask FixBot
    5. HP 7 1800 Motherboard Replacement, Remove the logic board: step 7, image 1 of 1
      • Carefully lift the motherboard directly up.
      Ask FixBot
TMD
792 Reputation
5 Guides authored
USF Tampa, Team 4-1, Brown Winter 2015 Member of USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Members
84 Guides authored
1 Guide Comment
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
jakehittinger - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 86
All Time: 1,461
