Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Garmin Edge 530 Fails to Charge
The product will not power on and shows no signs of charging.
Faulty Charging Port
If the Garmin Edge battery is functioning properly, but the device will not charge, the issue may be with the device itself. This particular device can be charged via the wall outlet or a USB port. First, ensure that both of these options are fully functional. If the issue is not resolved with a functioning charger, it is likely that the issue is caused by a faulty or broken charging port. If the charging port is broken, follow the instructions found on the Garmin Edge 530 Charging Port Replacement to replace it.
Faulty Battery
If the Garmin Edge will not turn on despite being connected to a functional charging device, the issue may be found in the battery. The Garmin Edge 530 uses a built-in lithium ion battery. For further information on replacing this part view the Garmin Edge 530 Battery Replacement page.
Garmin Edge 530 and Smartphone Failing to Connect
Device is not pairing with smartphone and returning error messages.
Bluetooth is Not Enabled
The Garmin Edge 530 and your smartphone cannot pair if Bluetooth is not turned on. Make sure that Bluetooth is enabled on both devices before attempting to connect the devices.
Garmin Edge 530 and Smartphone Need to Restart
Sometimes restarting both devices will help to sync up their connectivity. First, turn off the smartphone and the Garmin Edge 530, wait a few seconds, and then turn them back on again.
Garmin Edge 530 Will Not Bluetooth Pair to Smartphone
If the Garmin Edge 530 and your smartphone are not connecting after ensuring bluetooth is enabled and doing a restart, you may have to retry the pairing process by removing the Garmin Edge 530 from the Garmin Connect app and the bluetooth settings on your smartphone. The steps are as follows:
  1. Open the Garmin Connect app and go to More (or Menu for android devices), select Garmin Devices > Garmin Edge 530 > “Remove” > confirm device removal.
  2. Go to your smartphone’s bluetooth settings, select the Garmin Edge 530 in the list of devices, and select “forget this device” (or “unpair” for android).
  3. On the Edge 530, go to Menu > Phone > select the name of your phone > Forget Phone.
  4. To reconnect the devices and re-enter pairing mode, go back into the Garmin Connect app and select More (or Menu), select Garmin Devices > Add Device to re-add the Garmin Edge 530.
  5. Place the Garmin Edge 530 into pairing mode by going to Menu > Settings > Connected Features > Phone > Pair Smartphone.
  6. Go back into the Garmin Connect app and select “Start” or “Connect it,” inputting the 6 digit pin when prompted, syncing the devices.
Garmin Edge 530 Fails to Stay In Place
The device will not stay connected to the mount.
Faulty Mount
Many times, the mount used to secure the Garmin Edge 530 in place during a ride will fail. If you notice your device coming disconnected from the mount, notice visible defects in the mount, or see that the mount itself is disconnecting from your bike, you may have a faulty mount.
Back Cover is Defective
Summary: If the mount itself is not at fault, you may have a defect in the back cover of your Garmin Edge. Look for obvious breaking or warping of back structures. If the piece is broken, follow instructions found on the Garmin Edge 530 Back Cover Replacement to replace the faulty part.
Screen is Black or Blank
Screen will not turn on or display information despite being fully charged.
Cracked or Damaged Screen
Look for any visible defects to the screen, any deep scratches, or obvious breaks. If the screen is in need of repair, follow Garmin Edge 530 LCD Screen Display Replacement to find step-by-step instructions.
Internal LCD Screen Display is Defective or Broken
Sometimes the internal parts of the Garmin Edge 530 that work to make up the LCD screen display of the device will break or go bad. If this is the case, there should be no visible defects in the screen, the device will turn on and fully charge, but the screen will remain dark or blank. Make sure that the screen is not in need of repair before troubleshooting the internal display. If the display is no longer functional, follow the Garmin Edge 530 LCD Screen Display Replacement to replace the faulty part.
Faulty Motherboard
There may be issues with the motherboard connecting to the internal LCD screen display or is faulty over time. If you notice the screen is turning on and lighting up, but is returning a blank white screen at a dimmer brightness, while the screen has no defects and is able to charge, the issue may lie with the motherboard. Make sure that the internal LCD screen display is not in need of repair before troubleshooting the motherboard. If the motherboard is in need of replacement, follow the Garmin Edge 530 Motherboard Replacement for step-by-step instructions.
Inaccurate Elevation and Grade Readings
Indicated elevation and grade are inaccurate during rides.
The Barometric Altimeter is Wet
If the Garmin Edge 530 is returning inaccurate elevation and grade readings while all other functions are operational, especially after exposure to water, the barometric altimeter may be wet. The barometric altimeter is housed on the back of the Garmin Edge 530 behind two small hole openings located above the serial number. To remove moisture from the barometric altimeter, take a hairdryer and gently apply heat to the small openings. The device can also be placed in rice to remove moisture from this area.
Dust and Debris Blocking Barometric Altimeter
If The Garmin Edge 530 has not been exposed to moisture but is still returning inaccurate elevation and grade readings, the small openings may be blocked with dust and debris. To remove this, use compressed air to gently blow the dust and debris out from the openings.
2 SolutionsGarmin Edge 530 Fails to Charge
The product does not power on and shows no signs of charging.
Potential causes include a faulty charging port or a faulty battery.
3 SolutionsGarmin Edge 530 Fails to Connect to Smartphone
The device is not pairing with the smartphone and is returning error messages.
Potential causes include Bluetooth not being enabled, both the Garmin Edge 530 and smartphone needing a restart, or the Garmin Edge 530 not being able to pair with the smartphone via Bluetooth.
2 SolutionsGarmin Edge 530 Fails to Stay in Place
Potential causes include a faulty mount or a defective back cover.
3 SolutionsGarmin Edge 530 Black or Blank Screen
The screen will not turn on or display information despite being fully charged.
Potential causes include a cracked or damaged screen, a defective or broken internal LCD screen display, or a faulty motherboard.
2 SolutionsGarmin Edge 530 Inaccurate Elevation and Grade Readings
The indicated elevation and grade are inaccurate during rides.
Potential causes include a wet barometric altimeter or dust and debris blocking the barometric altimeter.
Author
with
Lainey Merriwether
662 Reputation
2 Guides authored
Clemson, Team 2-1, Hunter Spring 2022 Member of Clemson, Team 2-1, Hunter Spring 2022
CLEM-HUNTER-S22S2G1
5 Members
60 Guides authored
5 Comments
My Garmin Edge 530 suffers from 2 problems. First is the gradient reading, which appears to average the last couple of hundred meters instead of giving something approaching an immediate value. obviously it needs to register some pressure difference to provide a reading but I would rather have a slightly less precise reading relating the gradient I'm actually on. My 510 was far superior in this regard.
second: as my house is at 120m above sea level I set this elevation at the beginning of a ride. Just round the corner from my house and within a couple of minutes it is showing a significantly different altitude, e.g. 135m
These problems occur every time I use the 530, regardless of whether it is wet or dry and I can't detect any blockage of the barometer sensor. These issues have been happening since the 530 was brand new.
John Wright - Reply Share
Same issue, elvation way underrecording compared to my fenix 6 and 520 plus
Greg Philps - Reply Share
My Garmin 530 is not connecting to any sensors anymore neither does it connect to my watch on extended display. I have rebooted the device and have deleted it from my iPhone and reconnected it, but still same issue. Before the error happened the device rebooted twice and the end of a ride. Is it a failure of the device or can it be fixed somehow?
Rene de Jong - Reply Share
My garmin 530 is - when I select activity profile "Road" it does not start or show correct power readings
Brian Leslie - Reply Share
I cracked the screen of my Garmin Edge after a crash. I replaced the display. Initially, it went on and off randomly. After pressing the display to the unit for 12h with some clamps the display seems to work rather stably now. However, the beep-sounds of the unit are gone (sound are enabled in the device-settings). Any advise? Is it possible that the piezo broke during the crash? The motherboard seemed unharmed, apart from one of the golden clamps on top, that press on the display from behind which was bend What is their function anyway?
Google Konto - Reply Share
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 136
All Time: 21,065
