Garmin Edge 530 Battery Replacement
Views: 33K
View statistics:
Past 24 Hours:
21
Past 7 Days:
133
Past 30 Days:
509
All Time:
32,864
Comments: 8
1 comment on steps, 7 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 55 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to access, remove, and replace the battery of a Garmin Edge 530 device.
It may be necessary to replace the battery if the device is not turning on, or if the device has been damaged. You should troubleshoot to determine that the screen is operating properly before resorting to battery replacement.
The Garmin Edge 530 operates using a lithium-ion battery. This battery part can come as an individual battery or pre-packaged in a back case. If the part you order includes a back case, you should refer to the back case replacement guide for further instruction.
In this guide, you will have to pry up the glass panel with a metal spudger. It is important to note the potential broken glass hazard when prying the screen from the back cover. After this step, use ESD-safe tools to avoid damage to the rest of the device and protect it from electrostatic discharge.
A punctured battery can cause a fire. If the battery is swollen, it should be handled properly.
Before beginning, power down the device and disconnect from any external power sources.
Parts
Tools
    1. Garmin Edge 530 Battery Replacement, LCD Screen Display: step 1, image 1 of 1
      • Insert the metal spudger between the edge of the device screen and back cover.
      • Begin to pry along the perimeter between the device screen and back cover.
      Ask FixBot
    2. Garmin Edge 530 Battery Replacement: step 2, image 1 of 3 Garmin Edge 530 Battery Replacement: step 2, image 2 of 3 Garmin Edge 530 Battery Replacement: step 2, image 3 of 3
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
      • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
      Ask FixBot
    3. Garmin Edge 530 Battery Replacement: step 3, image 1 of 3 Garmin Edge 530 Battery Replacement: step 3, image 2 of 3 Garmin Edge 530 Battery Replacement: step 3, image 3 of 3
      • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
      Ask FixBot
    4. Garmin Edge 530 Battery Replacement: step 4, image 1 of 1
      • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
      • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
      Ask FixBot
    1. Garmin Edge 530 Battery Replacement, Motherboard: step 5, image 1 of 2 Garmin Edge 530 Battery Replacement, Motherboard: step 5, image 2 of 2
      Halberd Spudger
      $2.99
      Buy
      • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
      • Gently peel back the copper adhesive strip to free the remaining bonding cable.
      Ask FixBot
    2. Garmin Edge 530 Battery Replacement: step 6, image 1 of 1
      • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
      Ask FixBot
    3. Garmin Edge 530 Battery Replacement: step 7, image 1 of 2 Garmin Edge 530 Battery Replacement: step 7, image 2 of 2
      • Take the motherboard out of the back cover.
      • You will remove the wire harness in the next step.
      Ask FixBot
    4. Garmin Edge 530 Battery Replacement: step 8, image 1 of 3 Garmin Edge 530 Battery Replacement: step 8, image 2 of 3 Garmin Edge 530 Battery Replacement: step 8, image 3 of 3
      $3.99
      Buy
      • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
      • Now the motherboard and compartment are separated.
      Ask FixBot
    1. Garmin Edge 530 Battery Replacement, Battery: step 9, image 1 of 2 Garmin Edge 530 Battery Replacement, Battery: step 9, image 2 of 2
      Halberd Spudger
      $2.99
      Buy
      • Use a nylon halberd spudger to pry up the orange ribbon cable connecting the battery to the charging port.
      • Fully remove the orange ribbon cable from the charging port.
      Ask FixBot
    2. Garmin Edge 530 Battery Replacement: step 10, image 1 of 3 Garmin Edge 530 Battery Replacement: step 10, image 2 of 3 Garmin Edge 530 Battery Replacement: step 10, image 3 of 3
      • Use the nylon halberd spudger to peel the battery from the adhesive holding it into the back case.
      • Gently pry up the edges of the battery.
      • Once the adhesive has been separated from the battery, carefully lift it out of the back case.
      Ask FixBot
7 other people completed this guide.
Lainey Merriwether
662 Reputation
2 Guides authored
Clemson, Team 2-1, Hunter Spring 2022 Member of Clemson, Team 2-1, Hunter Spring 2022
CLEM-HUNTER-S22S2G1
5 Members
60 Guides authored
7 Guide Comments
how is the screen glued back in?
Peter Gee - Reply Share
You might use the T-8000 glue
Andrea Castellani - Reply Share
How do those 3 cables get reattached? Do they need to be soldered or are they just pushed back into the black clip?
paulbreslin1983 - Reply Share
How do those 3 cables go back in, just push into bracket? Do they need to be soldered?
Why you need motherboard?
Mo L - Reply Share
Past 24 Hours: 21
Past 7 Days: 133
Past 30 Days: 509
All Time: 32,864
