Garmin Edge 530 Motherboard Replacement
  1. Garmin Edge 530 Motherboard Replacement, LCD Screen Display: step 1, image 1 of 1
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
    Ask FixBot
  2. Garmin Edge 530 Motherboard Replacement: step 2, image 1 of 3 Garmin Edge 530 Motherboard Replacement: step 2, image 2 of 3 Garmin Edge 530 Motherboard Replacement: step 2, image 3 of 3
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
    Ask FixBot
  3. Garmin Edge 530 Motherboard Replacement: step 3, image 1 of 3 Garmin Edge 530 Motherboard Replacement: step 3, image 2 of 3 Garmin Edge 530 Motherboard Replacement: step 3, image 3 of 3
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
    Ask FixBot
  4. Garmin Edge 530 Motherboard Replacement: step 4, image 1 of 1
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
    Ask FixBot
  5. Garmin Edge 530 Motherboard Replacement, Motherboard: step 5, image 1 of 2 Garmin Edge 530 Motherboard Replacement, Motherboard: step 5, image 2 of 2
    Halberd Spudger
    $2.99
    Buy
    • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
    • Gently peel back the copper adhesive strip to free the remaining bonding cable.
    Ask FixBot
  6. Garmin Edge 530 Motherboard Replacement: step 6, image 1 of 1
    • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
    Ask FixBot
  7. Garmin Edge 530 Motherboard Replacement: step 7, image 1 of 2 Garmin Edge 530 Motherboard Replacement: step 7, image 2 of 2
    • Take the motherboard out of the back cover.
    • You will remove the wire harness in the next step.
    Ask FixBot
  8. Garmin Edge 530 Motherboard Replacement: step 8, image 1 of 3 Garmin Edge 530 Motherboard Replacement: step 8, image 2 of 3 Garmin Edge 530 Motherboard Replacement: step 8, image 3 of 3
    $3.99
    Buy
    • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
    • Now the motherboard and compartment are separated.
    Ask FixBot
2 other people completed this guide.
Harrison Stafford
198 Reputation
1 Guide authored
Clemson, Team 2-1, Hunter Spring 2022 Member of Clemson, Team 2-1, Hunter Spring 2022
CLEM-HUNTER-S22S2G1
5 Members
18 Guides authored
2 Guide Comments
Can you guys do a repair on the buttons? I had a stuck button, I popped it off, now I can't get it back on :(
Jonathan Fisher - Reply Share
Guide failed to mention to detatch the ribbon cable from under the copper tape after removing the connector at step 5
Paul Jackson - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 119
All Time: 5,358
