Garmin Edge 530 Charging Port Replacement
  1. Garmin Edge 530 Charging Port Replacement, LCD Screen Display: step 1, image 1 of 1
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
    Ask FixBot
  2. Garmin Edge 530 Charging Port Replacement: step 2, image 1 of 3 Garmin Edge 530 Charging Port Replacement: step 2, image 2 of 3 Garmin Edge 530 Charging Port Replacement: step 2, image 3 of 3
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
    Ask FixBot
  3. Garmin Edge 530 Charging Port Replacement: step 3, image 1 of 3 Garmin Edge 530 Charging Port Replacement: step 3, image 2 of 3 Garmin Edge 530 Charging Port Replacement: step 3, image 3 of 3
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
    Ask FixBot
  4. Garmin Edge 530 Charging Port Replacement: step 4, image 1 of 1
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
    Ask FixBot
  5. Garmin Edge 530 Charging Port Replacement, Motherboard: step 5, image 1 of 2 Garmin Edge 530 Charging Port Replacement, Motherboard: step 5, image 2 of 2
    Halberd Spudger
    $2.99
    Buy
    • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
    • Gently peel back the copper adhesive strip to free the remaining bonding cable.
    Ask FixBot
  6. Garmin Edge 530 Charging Port Replacement: step 6, image 1 of 1
    • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
    Ask FixBot
  7. Garmin Edge 530 Charging Port Replacement: step 7, image 1 of 2 Garmin Edge 530 Charging Port Replacement: step 7, image 2 of 2
    • Take the motherboard out of the back cover.
    • You will remove the wire harness in the next step.
    Ask FixBot
  8. Garmin Edge 530 Charging Port Replacement: step 8, image 1 of 3 Garmin Edge 530 Charging Port Replacement: step 8, image 2 of 3 Garmin Edge 530 Charging Port Replacement: step 8, image 3 of 3
    $3.99
    Buy
    • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
    • Now the motherboard and compartment are separated.
    Ask FixBot
  9. Garmin Edge 530 Charging Port Replacement, Battery: step 9, image 1 of 2 Garmin Edge 530 Charging Port Replacement, Battery: step 9, image 2 of 2
    Halberd Spudger
    $2.99
    Buy
    • Use a nylon halberd spudger to pry up the orange ribbon cable connecting the battery to the charging port.
    • Fully remove the orange ribbon cable from the charging port.
    Ask FixBot
  10. Garmin Edge 530 Charging Port Replacement: step 10, image 1 of 3 Garmin Edge 530 Charging Port Replacement: step 10, image 2 of 3 Garmin Edge 530 Charging Port Replacement: step 10, image 3 of 3
    • Use the nylon halberd spudger to peel the battery from the adhesive holding it into the back case.
    • Gently pry up the edges of the battery.
    • Once the adhesive has been separated from the battery, carefully lift it out of the back case.
    Ask FixBot
  11. Garmin Edge 530 Charging Port Replacement, Charging Port: step 11, image 1 of 3 Garmin Edge 530 Charging Port Replacement, Charging Port: step 11, image 2 of 3 Garmin Edge 530 Charging Port Replacement, Charging Port: step 11, image 3 of 3
    • Hold the GPS to where you can see the charging port from inside of the GPS.
    • Use a T5 Torx screwdriver to remove the two 6 mm screws holding the charging port in place.
    Ask FixBot
  12. Garmin Edge 530 Charging Port Replacement: step 12, image 1 of 3 Garmin Edge 530 Charging Port Replacement: step 12, image 2 of 3 Garmin Edge 530 Charging Port Replacement: step 12, image 3 of 3
    Halberd Spudger
    $2.99
    Buy
    • Open up the charging port and use the nylon halberd spudger to push the charging port towards the inside of the GPS to remove it.
    • Completely pull out the charging port from the compartment.
    Ask FixBot
2 other people completed this guide.
Brooke Holladay
127 Reputation
1 Guide authored
Clemson, Team 2-1, Hunter Spring 2022 Member of Clemson, Team 2-1, Hunter Spring 2022
CLEM-HUNTER-S22S2G1
5 Members
18 Guides authored
1 Guide Comment
Thanks - but there is no link for the actual charge port. Does this require soldering in? - a scan of eBay only shows a part to be soldered, can anyone recommend the best part to buy - ideally no soldering?
jon laurence - Reply Share
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 106
All Time: 6,463
