Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Vacuum Has Poor/No Suction
The Dirt Devil Gator is not picking up dirt and debris.
Clogged Air Filter
You’ve already picked up too much stuff! Open the filter chamber by firmly pressing on the “filter button" on the top of the vacuum and pull the vacuum chamber away from the handle. Once removed, acquire the filter, and empty its components into the trash. If you are unable to remove the obstruction, replace the filter.
Clogged Exhaust Filter
Remove the exhaust filter from the back of the Dirt Devil Gator by unscrewing the back half of the vacuum to reach the inside of the exhaust filters. Then, remove the obstruction from its vents. If the obstruction is something smaller like hair or dust bunnies, remove with hand and throw away. If the obstruction is something bigger you may need assistance to remove it, like pliers.
Clogged or Obstructed Opening
If you cannot see into the vacuum, shine a light down the opening to make the interior visible, remove the obstruction, and continue use as intended! If the obstruction is something smaller like hair or dust bunnies, remove with hand and throw away. If the obstruction is something bigger you may need assistance to remove it, like pliers.
Vacuum Is Clogged Of Debris/Spitting out Dust
The Dirt Devil Gator is clogged of debris or spitting out previously picked up dirt.
Clogged Air Filter
Make sure the vacuum opening is not clogged! If you cannot see into the vacuum, shine a light down the opening to make the interior visible, remove the obstruction, and continue use as intended! If the obstruction is something smaller like hair or dust bunnies, remove with hand and throw away. If the obstruction is something bigger you may need assistance to remove it, like pliers.
The Motor Is Not Working
The device is not creating suction nor responding to the power switch.
Obstructed Motor
If the device is not creating sufficient suction or powering on, the motor could be obstructed. Unscrew the screws from the side of the Dirt Devil Gator. Once removed, notice the motor device (the largest one) and inspect to ensure no dirt or debris is obstructing or damaging the motor or its fans! If nothing is obstructing the fans, you will need to replace the motor to restore your device.
Dead Motor/Motor Fan
If the device is not creating sufficient suction or powering on, the motor or its fans could be dead. Unscrew the screws from the side of the device. Power on the vacuum and observe the motor. If the motor makes a sound when powered on, the motor fan may be obstructed/broken, and you should look to get it replaced. If the motor does not make any kind of response to the power being on, the motor will need to be replaced altogether.
Vacuum Will Not Start/Stay On For Long
The Dirt Devil Gator will not power on or remain powered on for more than 15 seconds.
Dead Battery
The Dirt Devil Gator is wireless, so it must charge! Charge the battery, if the dead battery won’t hold a charge, a replacement to the battery can be done to restore the battery to its working condition.
Defective Circuit Board
The battery in the device may not be working properly, not allowing the switch in the vacuum to efficiently work. Remove the screws from the side of the device to reach the interior of the Dirt Devil Gator to replace the circuit board. Notice the wiring of the switch to ensure it is fully intact, otherwise re-wire to the switch!
Defective Charger Port
The charger port keeps the vacuum in the Dirt Devil Gator able to be charged and ready to clean everything! If the Dirt Devil Gator will not sufficiently charge or stay powered, the charger port could be malfunctioning. The charger port is underneath the handle of the device. Examine the port to ensure it is not broken, obstructed, or malfunctioning. Otherwise, a charger port replacement would have to take place to keep it in pristine, working conditions!
Vacuum Is Overheating
The Dirt Devil Gator is malfunctioning and feels very warm to the touch.
Overuse
Let it rest for 15 minutes to cool down. If you are vacuuming too much, you may want to upgrade to a bigger vacuum that can cover larger distances and areas!
Clogged Air Filter/Exhaust Filter
Don’t forget the vacuum does have a maximum capacity of dirt that it can pick up! Make sure you empty the filter and ensure the exhaust filter in the back is empty and clear of obstructions. You can do this by opening the filter chamber, acquire the filter, and empty it into the trash. If the obstruction is something smaller like hair or dust bunnies, remove with hand and throw away. If the obstruction is something bigger you may need assistance to remove it, like pliers. Follow this filter replacement to ensure a hasty process to restore your Dirt Devil Gator.
Additional Sources
 https://www.vacuumtechy.com/dirt-devil-s...
Author
with
Ryan Marando
703 Reputation
5 Guides authored
1 Comment
Took it out of the box put it together plug it in an not charging the light flashes three time then for more times for total of five
clb best - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 43
All Time: 10,148
