Up to 20% off select tools
Dirt Devil Gator Filter Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
88
All Time:
1,591
Comments: 3
3 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your Dirt Devil Gator (Model Number: BD10100) isn’t creating suction, picking up debris, or functioning properly, you may need to replace the filter. Follow this guide to clean/replace the filter on your device.
However before using this guide, you may not need to fully replace the filter, just clean it. A clogged air filter is a simple problem with a quick fix to get you started vacuuming again quickly!
The filter on the Dirt Devil Gator helps collect dirt and debris from the ground into your vacuum. A clogged filter will not pick up dirt or hold on to already picked up debris. If the filter is destroyed, it will need a replacement.
Before beginning, make sure to power off your device completely and disconnect from any external power source.
    1. Dirt Devil Gator Filter Replacement, Filter: step 1, image 1 of 1
      • To get to the filter, press the button on the top of the vacuum to split your device in two.
      Ask FixBot
    2. Dirt Devil Gator Filter Replacement: step 2, image 1 of 3 Dirt Devil Gator Filter Replacement: step 2, image 2 of 3 Dirt Devil Gator Filter Replacement: step 2, image 3 of 3
      • Remove your Dirt Devil Gator into its two components by pulling apart.
      Ask FixBot
    3. Dirt Devil Gator Filter Replacement: step 3, image 1 of 2 Dirt Devil Gator Filter Replacement: step 3, image 2 of 2
      • Turn over the front half of the device.
      Ask FixBot
    4. Dirt Devil Gator Filter Replacement: step 4, image 1 of 3 Dirt Devil Gator Filter Replacement: step 4, image 2 of 3 Dirt Devil Gator Filter Replacement: step 4, image 3 of 3
      • Press the two grey buttons on either side of the filter chamber inwards to release the chamber.
      Ask FixBot
    5. Dirt Devil Gator Filter Replacement: step 5, image 1 of 1
      • Remove all debris and obstructions around the filter itself.
      • Remove from the filter chamber by pulling out the filter.
      Ask FixBot
    6. Dirt Devil Gator Filter Replacement: step 6, image 1 of 1
      • Replace it with a new or restored filter by placing it back in the filter chamber.
      Ask FixBot
2 other people completed this guide.
Author
with
Ryan Marando
703 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 88
All Time: 1,591
