Dirt Devil Gator Battery Replacement
    1. Dirt Devil Gator Battery Replacement, Battery: step 1, image 1 of 1
      • Press the button on the middle of the vacuum by pushing down on it and pulling the device apart.
      Ask FixBot
    2. Dirt Devil Gator Battery Replacement: step 2, image 1 of 3 Dirt Devil Gator Battery Replacement: step 2, image 2 of 3 Dirt Devil Gator Battery Replacement: step 2, image 3 of 3
      • Separate the vacuum by pulling on the back of the vacuum. There should not be heavy resistance when pulling.
      Ask FixBot
    3. Dirt Devil Gator Battery Replacement: step 3, image 1 of 3 Dirt Devil Gator Battery Replacement: step 3, image 2 of 3 Dirt Devil Gator Battery Replacement: step 3, image 3 of 3
      • Unscrew each of the 13 mm screws with the micro screwdriver from the vacuum.
      • Once unscrewed, pull the case of the Dirt Devil Gator apart.
      Ask FixBot
    4. Dirt Devil Gator Battery Replacement: step 4, image 1 of 3 Dirt Devil Gator Battery Replacement: step 4, image 2 of 3 Dirt Devil Gator Battery Replacement: step 4, image 3 of 3
      • Pull out the grey switch and circuit board from its slot in the red case.
      • Remove all of the wires from the vacuum to where only the battery and wires are left.
      • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
      Ask FixBot
    5. Dirt Devil Gator Battery Replacement: step 5, image 1 of 2 Dirt Devil Gator Battery Replacement: step 5, image 2 of 2
      • Cut the white and black wires with wire cutters to disconnect battery from the motor. Follow this guide to desolder!
      • Remove the tan couplings from their white sockets and replace with new batteries.
      • If the battery is torn or has battery acid around it, do not touch the battery. Safely dispose the battery. If come into contact with acid, wash hands thoroughly.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. The battery is not likely to fail, but if it does when following these steps, you will see something immediately wrong.
3 Guide Comments
So, where can I purchase a battery replacement?
ed1660wmh - Reply Share
You neglected to mention one VITAL item, what is the part number for the replacement batteries or where does one find those? I've searched all over the internet and cannot find them anywhere. The company says they are NOT user serviceable or replaceable parts. For me, it's not a matter of being able to the job, I definitely can, but it is not possible without the parts.
Vince Pepple - Reply Share
Judging by the pictures, the battery seems to be comprised of standard sub-c NiCd cells.
You would probably also be able to use NiMh cells, which would grant you a little more runtime and can be bought pretty much everywhere.
RobinKemen - Reply Share
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 86
All Time: 8,919
