Dirt Devil Gator Circuit Board Replacement
    1. Dirt Devil Gator Circuit Board Replacement, Circuit Board: step 1, image 1 of 1
      • Press the button found in the middle of the vacuum downwards. Then, separate the front from the back of the device by gently pulling apart.
      Ask FixBot
    2. Dirt Devil Gator Circuit Board Replacement: step 2, image 1 of 3 Dirt Devil Gator Circuit Board Replacement: step 2, image 2 of 3 Dirt Devil Gator Circuit Board Replacement: step 2, image 3 of 3
      • Separate the front and the back and set the front aside.
      • Pull on the back of the vacuum, there should not be too much resistance when pulling it out.
      Ask FixBot
    3. Dirt Devil Gator Circuit Board Replacement: step 3, image 1 of 3 Dirt Devil Gator Circuit Board Replacement: step 3, image 2 of 3 Dirt Devil Gator Circuit Board Replacement: step 3, image 3 of 3
      • Unscrew each individual 13 mm screws from the vacuum with a micro screwdriver.
      • Once unscrewed, pull the case of the Dirt Devil Gator apart.
      Ask FixBot
    4. Dirt Devil Gator Circuit Board Replacement: step 4, image 1 of 3 Dirt Devil Gator Circuit Board Replacement: step 4, image 2 of 3 Dirt Devil Gator Circuit Board Replacement: step 4, image 3 of 3
      • Remove the grey switch from the top of the device by pulling gently. Then, remove the complete motor by also pulling gently out of socket.
      • Take note that the circuit is at the top of the vacuum and everything must be removed
      Ask FixBot
    5. Dirt Devil Gator Circuit Board Replacement: step 5, image 1 of 1
      • Remove the motor from your Dirt Devil Gator exterior by slightly pulling out the white motor.
      • Includes: batteries, motor, circuit board, wires
      Ask FixBot
    6. Dirt Devil Gator Circuit Board Replacement: step 6, image 1 of 2 Dirt Devil Gator Circuit Board Replacement: step 6, image 2 of 2
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 42
All Time: 939
