Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
PC Not Turning On
The PC won’t turn on.
Computer isn’t plugged in
If the computer isn't plugged in, then no electricity is going through the system and it therefore cannot power on. Make sure the power cable is plugged into the power supply on the back of the computer case.
Power Switch is not “on”
If the power switch isn't on, then electricity cannot flow through the system. Make sure the power switch is set to the "on" position (left is on, right is off).
Outlet, powerstrip, or other power source may be non-functional
If a power source isn't functional, or if a powerstrip or an outlet is dead, then the computer cannot receive electricity from the wall. You can test the power appliance with a known working electrical appliance (such as a charger, fan, lamp, etc) in order to determine if the power appliance is faulty. If an outlet isn't functioning properly, contact an electrician. Otherwise, replace the power appliance.
Faulty Power Supply
If the above three failed troubleshooting procedures failed, the cause may be a dead or faulty power supply. A power supply powers the components in the computer, and a faulty or dead one will fail to provide proper power. Common causes of dead or faulty power supplies include:
  • Age of Power Supply
  • Manufacturing Defects
  • Power Surges
    • If there was a power surge, other components will have to be checked since the power surge may have taken out more than one component.
If the power supply is dead, purchase a new one and follow this replacement guide: link.
_____________________________________________________________________________________
Computer Overheating
The computer overheats. Symptoms may include random restarts and random shutdowns.
Blocked Vents
Blocked vents will not allow the computer to ventilate; cool air won't be taken in and hot air won't be expelled. Make sure the fan vents aren't blocked by anything. Leave at least 6” of space around the vents for ventilation.
Dusty Fans or Case
Dusty fans or a dusty case will also block ventilation. Open up the case and check for dust. Fans are commonly located in the front and back of the case. More common locations include: in the power supply unit, on the CPU heatsink, and on any dedicated, high performance components, such as a dedicated video card.
Remove the dust with either compressed air or by manually removing them and cleaning them. If you are using compressed air, hold the blades still in order to prevent damage to the fan bearings.
Broken Fan
A broken fan can cause a computer to overheat. If a fan is not spinning while the computer is turned on, follow this guide to replace it.
Dusty Heat Sinks
Dusty heat sinks will not allow cool air to flow through them. The components with heat sinks installed produce the most heat, so this may cause the most problems with regards to an overheating computer.
To fix this, open up the case and locate the heat sinks (example: heatsink). Remove and clean the heat sinks (do not use water) and replace the thermal paste. To apply thermal paste, follow this (Thermal Paste Application Tutorial).
Computer Restarts Before Windows Loading Screen
The computer restarts before this screen.
Improperly Connected or Improperly Seated Components
Improperly seated or connected components may be getting loose during operation, which would therefore cause the computer to freeze. To fix this, turn off the computer and open up the case. Make sure all wires are plugged in securely. Make sure all peripherals on the motherboard, such as the video card and the RAM, are seated properly and aren't touching anything that are floating around in the case, such as wires.
Faulty RAM
If it still fails to boot into the loading screen, the RAM module may be faulty. This would cause random reboots since RAM stores the temporary data your computer uses to run.
Test the RAM module using memtest (Tutorial). If memtest fails, replace the RAM module(s) with the help of our RAM replacement guide.
Computer Restarts During Windows Loading Screen
The computer restarts (or freezes) during this screen.
Failing Hard Drive
A failing hard drive may be the cause of corrupted data. This will often corrupt the boot sector and therefore your ability to log onto Windows.
To test the hard drive, run a S.M.A.R.T. test. If the S.M.A.R.T. fails, the hard drive may be failing. Buy a new hard drive and follow the Hard Drive replacement guide.
If the S.M.A.R.T. status is positive, then the issue likely isn't the hard drive. Therefore, attempt to boot into "Safe Mode."
Corrupted Drivers or Programs
Corrupted drivers and programs may be conflicting with your computer hardware or other software, which may cause a restart when the driver loads.
If booting into "Safe Mode" succeeds, attempt to manually uninstall the most recently installed programs and drivers. One method to uninstall is to use the Device Manager.
Corrupted Boot Sector
A corrupted boot sector will cause a restart since the computer wouldn't know how to boot properly. Attempt to use the Windows 7 Startup Repair
If the Windows 7 Startup Repair fails, attempt to System Restore to an earlier known working date.
Faulty RAM
Follow these instructions (above).
Computer is Slow or Restarts or Stutters Randomly
The computer is slower than usual or the computer restarts or stutters randomly.
Overheating Computer
An overheating computer will cause sluggish performance because the components will throttle themselves in order to prevent damage from excessive heat.
To check temperatures, use the SpeedFan application (tutorial). Common maximum unsafe temperatures and throttle temperatures (for performance oriented components and for PCs built or bought within the last 4-5 years) include:
  • Intel i5/i7 CPU: 90°C, throttling begins at 95°C.
  • AMD CPU: 62°C, throttling begins at 70°C.
  • GPU: 85°C, throttling begins at 90°C.
  • Hard Drive: 60°C is considered unsafe. Hard drives are much more susceptible to heat problems due to the nature of storing data.
If you believe your computer is overheating, follow these troubleshooting procedures in order to bring down the temperatures.
Computer Infection
Adware, spyware, malware, trojans, worms, and viruses slow down computers by hogging computer resources in order to perform their own malicious activities. Perform a system scan with a well-reputed malware scanner, such as Malwarebytes Anti-Malware.
Corrupted Driver Install or Incompatible Drivers
Corrupted or incompatible drivers will cause software and hardware conflicts. This would cause the computer to slow down, restart, or stutter. Uninstall the most recently installed drivers if the issues began recently. One method is to use the Device Manager.
Quiet, Uneven, or No Audio Output
There is no audio coming out of the speakers or the headphones.
Bad Connection in Output
If there is a bad connection, the electrical signals won't be able to properly pass through the wires. Make sure the male jack is securely plugged into the female jack. If that doesn't work, use a paperclip or a needle to clean out the headphone jack. Do not use excessive force since excessive force may scratch the jack.
Broken Headphones or Speakers
If there are sharp kinks or stripped insulation in the wire, the metal wires that carry the audio signal may have been partially or fully severed. Try connecting the headphones or the speakers to any known working source and attempt to play music through that source. If the differences are the same throughout the sources you use, the issue may be in the headphones or the speakers themselves.
Faulty or No Drivers
Drivers allow your computer to communicate with the audio device. Upgrade (or downgrade) your current audio driver. Information about your integrated DAC (digital-to-analog converter) / AMP chip can be found on your respective manufacturer's website.
Product May Be Built That Way
If there were no determinable defects (such as channel imbalance, static, or simply no sound) when using multiple sources, the headphones or the speakers may be built that way. Middle to high-end headphones and speakers are generally less sensitive (i.e. they require more power to be as loud as other speakers). You may need to buy an after-market amplifier in order to supply more power to the headphones or the speakers.
No or Distorted Video Output
The image being displayed on the monitor is either nonexistent or distorted.
Not Plugged In or Loosely Plugged In
If the video card isn't plugged in or if it is loosely plugged in, it likely isn't sending the output through the display cable and to your monitor. Make sure the video card cable is plugged into the back of the video card and the back of the monitor.
Video Card May Not be Properly Installed Inside the Case
A video card that isn't properly installed will cause it to systematically lose connection or have no connection at all. If you know your computer contains a dedicated video card, open the case and make sure the video card is sitting properly in its respective PCI-Express slot.
If the card requires extra power, make sure the respective power connectors are plugged in.
Drivers allow your computer to communicate with the video card. If they aren't installed, the performance may be bad or the display may be non-existent.
Make sure the video card drivers are installed. To determine the video card, press WINDOWS + R (the key). Type in "dxdiag" without the quotes, and hit enter. Click on the tab "Display 1" and find the name. Once you determine the make and model of your Graphical Processing Unit (GPU) or video card, head to their respective site and download and install the drivers.
Dead Video Card
If the above troubleshooting procedures fail, the issue may be a dead video card. Replace the video card by following the Video Card replacement guide.
Author
with
David Lennon
10,219 Reputation
10 Guides authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
132 Guides authored
14 Comments
on and off button on my all in one pc doesn’t turn on
Robert Campanelli - Reply Share
“power supply is dead” link is 404.
andrewlafrance1 - Reply Share
My pc just cant find a bootable device
Nick Vaah - Reply Share
Change the legacy mode to UFEI or vice versa based on your motherboard
Aswarth VIP - Reply Share
Computer starts and beeps 1 time but no display
woody5452 - Reply Share
Past 24 Hours: 24
Past 7 Days: 147
Past 30 Days: 761
All Time: 40,466
