Up to 20% off select tools
Desktop PC Front Fan Replacement
Views: 33K
View statistics:
Past 24 Hours:
14
Past 7 Days:
62
Past 30 Days:
331
All Time:
32,765
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 39
39 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Internal fans keep a computer at a stable temperature while operating. A faulty fan can cause a computer to overheat. It is important that all fans are in working order. Replacing a fan is an important skill for desktop PC users.
    1. Desktop PC Front Fan Replacement, Left Panel: step 1, image 1 of 1
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      Ask FixBot
    2. Desktop PC Front Fan Replacement: step 2, image 1 of 2 Desktop PC Front Fan Replacement: step 2, image 2 of 2
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      Ask FixBot
    1. Desktop PC Front Fan Replacement, Front Fan: step 3, image 1 of 2 Desktop PC Front Fan Replacement, Front Fan: step 3, image 2 of 2
      • Push to unlatch three grey connectors on the front panel.
      Ask FixBot
    2. Desktop PC Front Fan Replacement: step 4, image 1 of 1
      • Disconnect the front panel from the computer face.
      Ask FixBot
    3. Desktop PC Front Fan Replacement: step 5, image 1 of 1
      • Remove four Phillips #2 head, 5mm screws holding in the fan.
      Ask FixBot
    4. Desktop PC Front Fan Replacement: step 6, image 1 of 1
      • Slide the fan out from the side of the casing.
      Ask FixBot
    5. Desktop PC Front Fan Replacement: step 7, image 1 of 1
      • Disconnect the power cable from the fan.
      Ask FixBot
39 other people completed this guide.
Author
with
David Lennon
10,219 Reputation
10 Guides authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
132 Guides authored
2 Guide Comments
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - Reply Share
I did this with my pc and I was able to restore and add a new fan because the other one wouldn’t work because the wire was snapped so I decided to replace it and this guide helped me
TechNinja - Reply Share
Past 24 Hours: 14
Past 7 Days: 62
Past 30 Days: 331
All Time: 32,765
