Up to 20% off select tools
Desktop PC Graphics Card Replacement
Views: 22K
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
190
All Time:
21,538
Comments: 7
4 comments on steps, 3 guide comments.
Go to guide comments
Completed: 86
86 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
A computer graphics card allows a computer to plug into a monitor and be displayed. Graphics cards are vital components for computers. Also, replacing a graphics card can help your computer run more quickly and smoothly.
    1. Desktop PC Graphics Card Replacement, Left Panel: step 1, image 1 of 1
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      Ask FixBot
    2. Desktop PC Graphics Card Replacement: step 2, image 1 of 2 Desktop PC Graphics Card Replacement: step 2, image 2 of 2
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      Ask FixBot
    1. Desktop PC Graphics Card Replacement, Graphics Card: step 3, image 1 of 1
      • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
      • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
      Ask FixBot
    2. Desktop PC Graphics Card Replacement: step 4, image 1 of 2 Desktop PC Graphics Card Replacement: step 4, image 2 of 2
      • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
      • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
      Ask FixBot
86 other people completed this guide.
Author
with
David Lennon
10,219 Reputation
10 Guides authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
132 Guides authored
3 Guide Comments
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Ons NA - Reply Share
I have a all in one pc so this is not relevant
Robert Campanelli - Reply Share
any diffrerences in slots?
benzy aceware - Reply Share
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 190
All Time: 21,538
