Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer Not Charging
The laptop will not turn on or will automatically shut down after being unplugged.
Is the charger lit up?
Computer Overheating
The computer is hot to touch and will most likely not turn on
Is fan clear of dust?
  • If it is clean check if you can hear the fan moving
  • If you did not hear it then the fan needs to be replaced. Use the Fan Replacement Guide
Screen Not Working
Screen will not show the display
If cracked, broken or any LEDs are burned, the screen is going to be replaced.
Adjust the LCD brightness on your laptop.
Connect to a HDMI or Mini-DisplayPort cable
  • Check to make sure the computer portion still works by using a different screen.
  • If the display shows up on the other device, then your screen is damaged and need to be replaced. Use the Screen Replacement Guide
Run Diagnostic:
  • Turn off the computer and wait till its completely off
  • Hold the D button while holding the off key as will. That’s going to put your computer in BIST mode
  • There will appear some changes or lines that have been appearing with you if there were any problems, then it’s going to have some multiple colors appearing. On the screen
  • Then the laptop is going to turn off
    • If you had any problems appearing through the test, that’s going to tell you, you will need to replace the screen. Use the Screen Replacement Guide
WIFI Issues
The computer will not find networks nearby
Wireless won't work or slow
  • WIFI not connecting
    • Test your internet connection on another device to make sure it is not your internet being down
      • If your internet works on other devices then the problem is your laptop
      • If your internet does not work on other devices
        • The problem is most likely not related to your laptop
  • If these do not work, then your Wireless Card needs to be replaced. Use the Wireless Card Replacement Guide
Mouse/Track Pad not Working
The mouse will not respond to touch
Is Driver Cupress Touchpad-5.5.1.59 Installed?
Use External Mouse
Enter the BIOS setup and run the program
  • Some other steps you could take is to go to Device Manager, and update any drives you might find under the page.
    • Looking at your mouse/track pad setting is important, to make sure your track pad is still connected with your laptop, if not, run all diagnostics given and if they all fail, you will need to replace the track pad. Use the Track Pad Replacement Guide
Molly Skinner
270 Reputation
2 Guides authored
USF Tampa, Team S6-G3, Lacy Spring 2017 Member of USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
4 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 2,471
