Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Powers down when unplugged
Laptop will not hold a charge when unplugged from the wall socket.
Faulty Battery
First, plug in the power adapter and see if the light is on or off. If it is on, then its the battery that is faulty.
Faulty Power Adapter
If the light does not turn on, it is the power adapter that is faulty. You may want to think about purchasing replacement parts depending on your situation.
Battery Replacement Guide
Keyboard Sticks
When keys are pressed they are slow and stuck.
Debris build up
If your keyboard starts to act sticky, it may be because of common debris inside of the keyboard. If it is a sticky substance, you want to use a lightly moistened cotton swab with rubbing alcohol. If there is dust and other particles, you can use a brush or compressed air to remove the debris from your keys
Keyboard Replacement Guide
No Audio
No sound coming from laptop or speakers plugged into the sound board.
Faulty Audio Card
Test the audio by plugging in different speakers and headphones to make sure it’s not an external issue. If the problem persists, try updating the driver software by going to Dell’s support page. Follow the instructions on the website to see if the drivers need an update. If they are up to date then you might have a faulty sound card.
If the problem persists you may need to purchase a new audio card.
Audio Card Replacement
No Display
The monitor on the Dell Latitude 3380 does not show anything.
Disabled Display
First make sure the display is not disabled in any way by holding down the “Fn” key and pressing the “F2” key. If the display was disabled by accident, this will reenable it.
If the problem still persists, try holding the windows key and pressing the “P” key and make sure you are not on projector mode.
If it still has no display, it could be your screen display malfunctioning. You may want to purchase new parts depending on your situation.
Display Assembly Replacement Guide
Touchpad is unresponsive
Touch pad does not respond when used.
Disabled touchpad
One of the most common causes of the touchpad not working is that it is disabled or turned off.
Check to see if you have not accidentally pressed these keys. It is usually the Fn key that combines with an F key, such as F1.
Touchpad turned off in settings
Check to see that the touchpad is enabled in the mouse setting located in the Windows settings under the “Devices” tab. Something may have messed up and disabled the touchpad in these settings. These settings are located in Settings -> Devices -> Touchpad.
Touchpad Replacement Guide
Michael Wood
401 Reputation
3 Guides authored
Gateway, Team 1-3, Pee Fall 2021 Member of Gateway, Team 1-3, Pee Fall 2021
GCC-PEE-F21S1G3
3 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 33
All Time: 1,048
