Dell Latitude 3380 Battery Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
79
All Time:
1,465
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Dell Latitude 3380 is failing to hold a charge, it most likely has a dead battery, which will require a replacement in order to fix the problem.
Before starting, make sure to properly shut down the laptop and drain all power. Also, make sure you have the replacement battery and the proper tools in order to do the repairs.
Parts
Tools
    1. Dell Latitude 3380 Battery Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Turn the laptop over so that the back is facing up.
      • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Latitude 3380 Battery Replacement: step 2, image 1 of 2 Dell Latitude 3380 Battery Replacement: step 2, image 2 of 2
      • Use an opening tool to pry the back cover away from the laptop.
      Ask FixBot
    1. Dell Latitude 3380 Battery Replacement, Battery: step 3, image 1 of 3 Dell Latitude 3380 Battery Replacement, Battery: step 3, image 2 of 3 Dell Latitude 3380 Battery Replacement, Battery: step 3, image 3 of 3
      • Remove the three 3 mm screws using a Phillips #0 screwdriver
      • Disconnect the the cable connected to the battery using a spudger.
      • Lift up on the outer edges of the battery to remove it from the laptop.
      Ask FixBot
Michael Wood
401 Reputation
3 Guides authored
Gateway, Team 1-3, Pee Fall 2021 Member of Gateway, Team 1-3, Pee Fall 2021
GCC-PEE-F21S1G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 79
All Time: 1,465
