Dell Latitude 3380 Audio Card Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
62
All Time:
694
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
if you cannot hear anything from your Dell Latitude 3380, it is possible that your audio card in the laptop has malfunctioned and may need to be replaced.
Before starting, make sure to properly shut down the laptop and drain all power. Also, make sure you have the replacement part and the proper tools in order to do the repairs.
Parts
Tools
    1. Dell Latitude 3380 Audio Card Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Audio Card Replacement, Back Cover: step 1, image 2 of 2
      • Turn the laptop over so that the back is facing up.
      • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Latitude 3380 Audio Card Replacement: step 2, image 1 of 2 Dell Latitude 3380 Audio Card Replacement: step 2, image 2 of 2
      • Use an opening tool to pry the back cover away from the laptop.
      Ask FixBot
    1. Dell Latitude 3380 Audio Card Replacement, Audio Card: step 3, image 1 of 3 Dell Latitude 3380 Audio Card Replacement, Audio Card: step 3, image 2 of 3 Dell Latitude 3380 Audio Card Replacement, Audio Card: step 3, image 3 of 3
      • Gently disconnect the audio jack from the motherboard.
      • Remove the single 3 mm screw using a Phillips #0 screwdriver.
      • Lift up on the audio card and remove it from the laptop.
      Ask FixBot
Michael Wood
401 Reputation
3 Guides authored
Gateway, Team 1-3, Pee Fall 2021 Member of Gateway, Team 1-3, Pee Fall 2021
GCC-PEE-F21S1G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 62
All Time: 694
