Dell Latitude 3380 Display Assembly Replacement
    1. Dell Latitude 3380 Display Assembly Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Display Assembly Replacement, Back Cover: step 1, image 2 of 2
      • Turn the laptop over so that the back is facing up.
      • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Latitude 3380 Display Assembly Replacement: step 2, image 1 of 2 Dell Latitude 3380 Display Assembly Replacement: step 2, image 2 of 2
      • Use an opening tool to pry the back cover away from the laptop.
      Ask FixBot
    1. Dell Latitude 3380 Display Assembly Replacement, Display Assembly: step 3, image 1 of 3 Dell Latitude 3380 Display Assembly Replacement, Display Assembly: step 3, image 2 of 3 Dell Latitude 3380 Display Assembly Replacement, Display Assembly: step 3, image 3 of 3
      • Remove the single 3 mm screw from the metal bracket using a Phillips #0 screwdriver.
      • Remove the metal bracket.
      • Use a spudger to gently detach the connector from the motherboard.
      Ask FixBot
    2. Dell Latitude 3380 Display Assembly Replacement: step 4, image 1 of 3 Dell Latitude 3380 Display Assembly Replacement: step 4, image 2 of 3 Dell Latitude 3380 Display Assembly Replacement: step 4, image 3 of 3
      • Remove the two 3 mm screws (four total) from both sides of the laptop using a Phillips #0 screwdriver.
      • Lift up the bottom part of the laptop to separate the display assembly from the rest of the laptop.
      Ask FixBot
Michael Wood
401 Reputation
3 Guides authored
Gateway, Team 1-3, Pee Fall 2021 Member of Gateway, Team 1-3, Pee Fall 2021
GCC-PEE-F21S1G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 62
All Time: 929
